Old 01-01-2008, 02:15 PM   #1
cobinder
Everything is work in progress
cobinder's Avatar
STOP!! brake system questions
I'm changing my 80 K20 to Hydroboost and all disc's. I believe my stock m/c is an 1-1/4" bore (it's so rusted I can't get the guts out).
I'm moving the master cylinder assembly to under the cab floorboard. So I want the brake line outlets on the opposite side from the stock m/c. All the master cylinders a can find to fit are only 1-1/8" bore. Is this a problem?
I have 39" military Michelins that are very heavy so I want good brakes.
thanks for any imput.
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 01-02-2008, 05:57 AM   #2
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: STOP!! brake system questions
Have you tried looking for big truck stuff, C30, K30, something like that? I got a C30 master cylinder in my truck, tis with the 1.25" bore, but ports are still on the wrong side...
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 01-02-2008, 09:12 AM   #3
LONGHAIR
Watch out for residual valves. When you convert to rear disc you need a different one for the rear brakes. The drum type valve holds more pressure in the lines because of the return springs on the shoes. If you run it like that with discs, there will be constant drag, wear, and of course heat. None of which is good.
Is this really an off road truck? Show truck?
LONGHAIR is offline   Reply With Quote
Old 01-03-2008, 05:23 PM   #4
cobinder
cobinder's Avatar
It's a functioning show truck. The body parts are too rare to do serious off roading
04 Honda CRF "500"
