![]() Join Date: Feb 2001
TH400 kickdown ??
I just got a 70 truck with factory 402 BB with 3 speed tranny. I want to convert it to TH400 trans. What style kickdown was used in 1970 - the carb mounted switch or the later gas pedal activated one? Thanks for any help.
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
Born Psycho
Re: TH400 kickdown ??
should be the carb mounted version if my memory serves me correctly. gas pedal style started in 71 with the cable instead of hard linkage. if i'm wrong someone will correct me, it's been a while since i messed around with a 2wd 70 model.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
According to my 1971 chassis service manual it shows a pic of the carb having a kickdown switch mounted to it.
Here is the pic.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 Last edited by skokie; 01-01-2008 at 06:25 PM. |
![]() Join Date: Aug 2003
That truck wouldn't happen to be a blue Suburban,would it? Send me your # again. I think I found a trans. speedo gear.
its all about the +6 inches
i KNOW in 72 it was on the pedal... I had thought it was moved in 71, but not 100% sure now. (that illistration is for cars)
However, as indicated above, for 70, it was on the carb. |
If any help. My 67 has a 350 backed by a TH400. My truck by spid lable to have be a v8 auto truck. Mine just has a vaccumn modulator. Stomp on it and it changes gears. Nothing mechanical. Must be newer. Ever seen a governer in person. Quite a cool device.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched |
member #16
![]() Join Date: Dec 1999
Heres a pic to go with the illustration.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
