Old 01-02-2008, 03:55 AM   #1
jokersbowtie
jokersbowtie's Avatar
4 speed Trans fluid
is there an easy way to add fluid to a 4 speed in my 84?
jokersbowtie is offline   Reply With Quote
Old 01-02-2008, 04:18 AM   #2
87Wrangler454
87Wrangler454's Avatar
Re: 4 speed Trans fluid
I put my fluid in a sturdy container that you can pressurize with shop air, run a rubber hose with a metal u bend ( I use 1/2" steel hydraulic pipe) into the side of the tranny, use an air regulator at the container set at zero then slowly turn it so the fluid is just moving usually 5# to 8# is all that is needed, allow it to fill so it just starts running out and replace plug. You can do this hookup on your bench and run the hose under the truck.
87Wrangler454 is offline   Reply With Quote
Old 01-02-2008, 04:38 AM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
SM465? Fill it through the shifter hole until it runs out the fill hole on the side.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 01-02-2008, 07:27 AM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Use an old grease gun or a big syringe, to move the fluid from one container and squirt it into another. It can be used as a turkey baster of a sort.
piecesparts is offline   Reply With Quote
Old 01-02-2008, 07:34 AM   #5
jokersbowtie
I got it. thanks
used a small funnel with clear hose, put it in place and filled form under hood
