Old 01-02-2008, 07:44 AM   #1
Ozark Tim
Ozark Tim's Avatar
A picture of a 2-tone bed fron panel off truck?
If anyone has a picture of a 2 tone ( with centerband ) bed off the truck, I would like to give one to the body shop so they get the paint correct.
Anyone????
Thanks for any help!
Ozark Tim is offline   Reply With Quote
Old 01-02-2008, 08:08 AM   #2
powell72
powell72's Avatar
Re: A picture of a 2-tone bed fron panel off truck?
If I understand what you're asking, the front bed panel doesn't have both colors on it like the bedsides do, just the primary color.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 01-02-2008, 09:26 AM   #3
Ozark Tim
Ozark Tim's Avatar
Actually mine does and fortunately it is still on the cab as an example but the bed I sent to the blaster and was so happy to get it there I forgot to snap a few pictures. Der!
The centerband color ( In my case with the current project, WHITE ) continues in from the bedsides and wraps around to a point where it is hard to see it end ( About 6" on both the cab and the bed ) when bed and cab are together.
I know all the plants tended to do things a bit different but this is the third truck out of the St. Louis plant that I have done with a centerband and they all were the same way, wrapped around so you couldnt see the center paint end between the cab and bed.
These two colors are a bit hard to differentiate but if you look hard you can see that the white centerband on this truck I had last year wraps around to a point where you cant really see it end on the front of the bed.
Thanks,
Old 01-02-2008, 10:31 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Here's the only pic I can find of my old halfhorn. Either a 71 or 72 longhorn (can't remember) it was a 307/Th350 3/4 ton Cheyenne longhorn.
The chalk lettering said Z84
Old 01-05-2008, 05:39 AM   #5
Ozark Tim
Ozark Tim's Avatar
Thanks for that picture! You even got my colors correct!
I appreciate the help,
Old 01-05-2008, 05:57 AM   #6
Longhorn Man
no problem at all.
