Broke Club =(
8 lug question!
Hey guys, i got the 8 lug drum set up on my truck. Im looking at putting a disc conversion on it, but are there conversion for it. i dont care if they go to 5 or 6 lug id prefer it. Just wondering if you would know of anything like this. thanks Bill
p.s. I have a spare 3/4 ton frame choped down to fit a short bed, free if you can just get it off my driveway! or if anyone wants to trade or buy my 3/4 ton axles. ![]() Last edited by Bills_49; 01-02-2008 at 08:15 AM. |
polishing a turd
Re: 8 lug question!
i ended up going to a nova clip on mine. there used to be a page around where a guy made his own caliper brackets, but it is gone now.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
Broke Club =(
Re: 8 lug question!
whats the difference from the 1/2 ton to 3/4 ton axle besides for studs, are the spindles a diff diameter?
Re: 8 lug question!
1/2 ton and 3/4 (6 lug) are the same spindle size. HD 3/4 ton (8lug) are larger and no one I know of makes a kit. We just completed a disc brake conversion on a customers truck but we replaced the axle with a 1/2 ton axle. We sell a disc conversion kit for 5 or 6 lug disc. The brackets are a simple thing to fabricate if you have the tools. The only thing you will need not easily available is the adaptor for the spindle to line up with the wheel bearings. The rest can be bought over the counter.
Broke Club =(
Re: 8 lug question!
ok good answer, thank you!
Re: 8 lug disc question!
I was working on an 8 lug disc conversion for 47-59 GM trucks but a death in the family and some work issues has placed it on the back burner. im tryin to get things wrapped up by the end of Jan and find a local guy to make my brackets as I dont have time.
All I have left is final mockup after I finish tapping my bracket holes. It will be a 13" disc w/ big chevy floating caliper and will be a bolt-on affair. no welding or drilling. Oh-and it uses stock hub so no bearing changes needed. Mark |
