shift knob removel???
how do you take the black shift knob off of an auto column shifter???
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Problem Child
![]() Join Date: Sep 2005
Re: shift knob removel???
I ended up buying a new shifter arm.It wouldnt come off
1972 gmc sierra grande 350/350 a/c soon`to get a new 350 ![]() ![]() ![]() |
i dont need a new one, im tryin to put something else on it
When I replaced mine I used a dremel tool to split the side.
so its pressed on instead of threaded???
Nick Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg 04 Silverado Daily Driver 68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665 "I'll beat you to the gas station!!" ![]() ![]() |
huh ???
I got one from a friend's junkyard one time. I had to pull like **** to get it to come off...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
If you want to save it, set it in a bowl of boiling hot water too soften the plastic up. It'll come off.
1997 GMC Sierra Ext 1965 Mustang |
its all about the +6 inches
And if you don't wanna save it, vise grips and a hammer should do the trick if you don't have a cut off wheel ore dremel tool.
Old Skool Club
![]() Join Date: Jun 2001
Or, I've got a bus-load of middle-school boys I can send to you. Tell them to "LEAVE IT ALONE", then turn your back and VOILA! It'll be done.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#11 | |
R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
![]() ![]() Greasemonkey I have one with no knob if I can find it ...let me know and I'll look for it in the Black Hole of parts AKA my garage you can have it
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
#12 | |
![]() ![]() thatd be cool man, thanks, let me know
#13 |
how do you take the lever off exactly???
#14 |
Problem Child
I used a punch and drove the pin out.Then the lever should just pull out
#15 |
Heat it and pull off
#16 |
so do i just pound the pin out and then pound it back in???
#17 |
Problem Child
Yeah just be careful and try not to scratch the paint on the column
#18 | |
but anyway for those that were wondering this is what i was up to
#19 |
Between Trucks...
That's Classic...
Beat it to fit, Paint it to match... ![]() |
#20 |
thanks man
and btw the boiling water trick worked really good
#21 |
Want to get rid of the old knob? I'm looking for one.
#22 |
as long as your not looking for show quality, its a bit grayish from the boiling water but it should buff out, send me a pm
#23 |
Real Projects never die
Thanks to andrewt2, he noticed that .50 cal you have hanging from your rear view.......@.@
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
