Old 01-03-2008, 04:30 AM   #1
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
6 lugs to 5 lugs
I want to do a 6 lug to 5 lug conversion. A neighbor has a 83 Chevy and it's a 5 lug all around. Will I be able to use the front and back suspension on my 69 Chevy?
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 01-03-2008, 05:14 AM   #2
70GMCer
70GMCer's Avatar
Re: 6 lugs to 5 lugs
The front you can without any changes. Not sure about the rear though....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-03-2008, 05:22 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you have a leaf spring rear on the 69, then all you'd have to do is cut off a shock mount and weld it onto the other side.
If you have a coil rear, you can do it with some more cutting and welding, and a kit to mount the panhard bar.
I would look at the gear ratio in the later rear before jumping at it, they had some 2.56 gears in some of those that will make it a total dog and MPG will likely not be anything to write home about.
Old 01-03-2008, 10:54 AM   #4
streetstar
streetstar's Avatar
places like CPP and Early Classic Enterprises sell replacement 5 lug axles and brake drums to make the rear conversion with your stock rearend.
The stuff from the 83 will work on the 69, (spindle and rotor, but you have to swap the tie rod ends and balljoints i believe to the later stuff)
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
