01-03-2008, 07:13 AM | #1 |
Its always something!
C 60 bearing help
I recently bought a 63 C 60. The guy I got it from took the left rear hub off & miss placed the inner bearing. Is the C 40 & 50 series rear ends the same as the 60 series? Are the rear ends the same as the 67-72 C 40-60's. Where is a good place to buy parts for this truck. I tried the local napa & oriellys & got nowhere. I have no idea what kind of rear end this is. It is a 2 speed if that helps. Any help would be great
Thanks Shane
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed Member of the patina club |
01-03-2008, 07:28 AM | #2 |
Rottenwood Garage Member
Re: C 60 bearing help
Im not sure if the are the same........40-50-5500-and 60's.........but i had good luck finding my stuff at Carquest.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 01-03-2008 at 10:02 AM. |
01-03-2008, 07:49 AM | #3 |
The bearings in your rear are based on the weight rating of the axles. Oriellys can get them for you if you know the weight rating of the axle, and can find a parts man in the store. Just tell them it isn't in the computer get a book. If the P.O. left the race in the hub that could help you find the bearings.
01-03-2008, 07:54 AM | #4 |
Firefighter
Your local NAPA should have the books with these bearings, the one that I work at does so if you can't find it I'll see if I can find it tomorrow.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
01-03-2008, 02:05 PM | #5 |
Next!
Rear should (could) be an Eaton.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
01-04-2008, 03:50 AM | #6 |
Firefighter
Do you know what rear end you have? I found the listing for the bearing but need to know what rear end you have.
01-04-2008, 05:09 AM | #7 |
I'm not sure what rear end I have. The truck is about an hour away from home. Can somebody get a pic of the 2 different types of rear ends?
01-04-2008, 06:53 AM | #8 |
Firefighter
Actually there is 14 different possibilities..
01-04-2008, 08:39 AM | #9 |
Holy crap! I didnt know there were that many possibilities. Looks like I may be making a trip down there this weekend.
01-04-2008, 09:19 AM | #10 |
Firefighter
Neither did I, till I looked in the book..
01-04-2008, 04:04 PM | #11 |
Look down.
Last edited by 89 crew; 01-04-2008 at 04:39 PM. Reason: Wrong information was given. |
01-04-2008, 04:08 PM | #12 |
Sorry I was thinking about the wrong post. The answer to this should help narrow it down. Does it have a few small bolts screwed in the end of the axle? a bunch of medium sized studs with nuts sticking out, Or a several Big studs sticking out the center?
01-04-2008, 04:13 PM | #13 |
Does it look like the hub in this picture? http://67-72chevytrucks.com/vboard/s...d.php?t=271986
01-04-2008, 08:34 PM | #14 |
Mine is different than the one in the pic. Mine is more like the 1 ton setup. The axle is splined where it goes into the hub & there is a cover that bolts over it.
01-04-2008, 08:51 PM | #15 |
Then it is between a 14000 lbs 17000 lbs. Do you happen to know what size tires are on it?
01-05-2008, 05:44 AM | #16 |
They are 20in rims. Not sure of the tire size.
01-05-2008, 02:18 PM | #17 |
They all run 20 inch rims but there is everything from a 7.25- 11.00x 20 it would be another hint as to the axle weight. at this time I would say your best bet is to pull the race and see what bearings fit that race between 14k and 17k There will probably only be one set. Your only other option is to crawl around the rear and find every set of numbers you can. Go to a gmc heavy truck dealerships parts room and they can find the right ones for you.
01-08-2008, 08:11 PM | #18 |
I have the # off the outer bearing & race if that helps. The bearing is A11950 the race is 11950Z
01-09-2008, 03:54 AM | #19 |
Firefighter
Inner bearing #B12235-YK this is a NAPA #. You have either a Rockwell Std G161 or G361 or you have an Eaton 22M, hope this helps!!
01-09-2008, 05:33 AM | #20 |
Cool!! Thanks for your help!
01-09-2008, 07:47 AM | #21 |
Firefighter
Anytime!!!!
