Old 01-03-2008, 07:30 AM   #1
panhandler62
Java Mechanic
panhandler62's Avatar
Welcome Back Cotter
I'm guessing that I'm not the first person to run into somehting like this --
I'm thinking angle grinder but thought I would check for less radical solutions first. lol (note my all but non-existant photoshop skills where I added the little arrow.)
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 01-03-2008, 07:36 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Welcome Back Cotter
whats the problem, can't get the cotter pin out?
If you have a decent impact and compressor at hand, then just cut/break off what you can, then zip it off with the impact.
Old 01-03-2008, 07:51 AM   #3
panhandler62
Java Mechanic
I don't have any air.. just hand tools.
That's the bottom ball joint so I don't think you could get on it with an impact anyway. :P
Keith
Old 01-03-2008, 07:57 AM   #4
greasemonkey
greasemonkey's Avatar
Can you drill it?
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 01-03-2008, 07:58 AM   #5
71swb4x4
71swb4x4's Avatar
Do what Andy is saying without an impact. Break the rest of the pin off and back the nut off. If worse-comes-to-worse use a big breaker bar with a pipe on it.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-03-2008, 08:00 AM   #6
webbes
Just drive a socket on it and turn out and then you can get the cotter pin out.
1970 4X4 LONG BED 350 TPI 700R4
webbes is offline   Reply With Quote
Old 01-03-2008, 09:21 AM   #7
Shane
Shane's Avatar
1/2 drive ratchet with a cheater pipe ... and lots of PB Blaster. I just discovered PB and the stuff is made with black magic and voodoo.
Shane is offline   Reply With Quote
Old 01-03-2008, 09:27 AM   #8
Weezer67
Ditto on the PB!
Weezer67
Dodge City, Kansas
Weezer67 is offline   Reply With Quote
Old 01-03-2008, 09:35 AM   #9
corn
PB works awesome when tapping threads. Try it...
corn is offline   Reply With Quote
Old 01-03-2008, 09:57 AM   #10
Shane
Shane's Avatar
I have, and you're right, it's flippin' awesome!
Old 01-03-2008, 10:07 AM   #11
panhandler62
Java Mechanic
It was a tought nut to handle..
Finaly had to cut the dang thing off
Keith
Old 01-03-2008, 10:17 AM   #12
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Be sure to leave a jack under the lower control arm to keep tension on the spring and avoid possible injury in case the lCA separates from the steering knuckle.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-03-2008, 10:31 AM   #13
beautimus
beautimus's Avatar
i realize that its a little to late now, but for future reference,
if you keep the thing wet with penetrating oil for a day or so,
and use a 3/32" pin punch, you can tap those things out pretty easy.
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 01-03-2008, 10:36 AM   #14
panhandler62
Java Mechanic
I did have a jack under there.. but it turns out that it wasn't needed.. I never could get the ball joints off.. which is ok since I am only saving the springs. Everything else is getting updated to '83 parts.
Keith
Old 01-03-2008, 10:58 AM   #15
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I've had a fw cotterpins break off inside the nut with a few fragments sticking out. i just hammered a socket on there past whatever was left & put my long rachet on it & gave it a pull & the nut spun off & just cut off the remainder of the pin.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 01-03-2008, 11:13 AM   #16
corn
Why did you go through all that work just to save the springs? Why not just use the '83 springs with the swap?
Old 01-03-2008, 11:22 AM   #17
panhandler62
Java Mechanic
Because I don't have the new springs.. I'm getting spindles, calipers, control arms, rotors, a booster, master cylinder, propertioning valve and a big dirty card board box. All being brought back from Indy when my wife passes through there on her way home from Oklahoma City.
I would have to pull the old control arms off any way you look at it.
Keith
