Accelerator Linkage change 6 to 8.
I am changing engines, 6 cly to a V8. The accelerator pedal linkage on the firewall is different on my 6 to a V8 truck, the 6 cly has a cable system where the V8 truck has a linkage that goes thru the firewall. Do I need to change these out since I am putting the V8 in? I know they are mounted differently. The V8 pedal linkage is mounted on the engine side of the firewall where the 6 is mounted inside the cab which would require some fabrication.
Richard Dobson |
member #16
![]() Join Date: Dec 1999
Re: Accelerator Linkage change 6 to 8.
Depends on the year of your truck. they went to the cable in 1971, prior years used the rod for both engines.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Yeah John my 6 cyl truck is a 71 Chevy, Is there a need to change the accelerator set-up I mentioned above which is in a 69 GMC V8?
Richard Dobson |
member #16
You just need to get a 8cyl cable. Its quite a job to change from one to the other.
I have swapped the inline for a 350 with a quadrajet in my previous 68. The only problem that ever happened was when the motor mount broke and would pull full throttle as engine lifted, ( left mount).
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched |
richard, i went from a 6 to v8 in my 71 c10, used the existing 6 throttle cable, i used a 2 barrel rochestor but it should be just fine for a 4 barrel as well. i got a bracket from the junkyard to hold the end of the cable to the intake, you may have to get a new ball stud to srew on to your carb linkage depending on the carb and etc. most guys prefer the cable setup versus the rod setup. safer in my opinion. good luck
'55 3100 2nd series short-bed stepside '70 Corvette coupe stingray '71 Chevelle 2-dr coupe SS clone '71 C10 long-bed fleetside '83 long-haired brunette wife |
