Alright Alright Alright
upper control arm washers
i recently replaced the upper control arm shaft in my 72 cheyenne. the kit came with everything but the large washers that go between the endcaps and the a arm. where might i find these and what size is the hole in the washer?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
Fabricate till you "puke"
Re: upper control arm washers
If you still have the steel bushings, there should be no washer tween the bushing & the arm.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
there were no steel bushings in the kit or on the control arms to begin with. it was just endcaps, rubber grommets that slid on to the shaft, and the shaft its self.
Ok, you must have later (73 up arms) on your 72. im not sure where to get those pcs, but you my try the help rack in some of the local auto parts stores. best of luck,crazyL
thanks for the info bro.
