Old 01-03-2008, 08:41 PM   #1
my70chevyc10
my70chevyc10's Avatar
Power steering pump
I have what i think is a problem the owner befor me put the power steering pump low on the driverside of the block now it is blocking the timing mark tab and now i cant use my timing light. Is there anything i can do please help.
"Your trucks fast! You must have been going 120 when I passed you."
"Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties...
my70chevyc10 is offline   Reply With Quote
Old 01-04-2008, 02:05 AM   #2
70GMCer
70GMCer's Avatar
Re: Power steering pump
Any pics....I'd like to see that one....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-04-2008, 02:17 AM   #3
truckdude239
truckdude239's Avatar
umm my time mark is on the passager side. i'd like to see this beacue theres only one place where it can bolt i thought
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-05-2008, 08:56 AM   #4
my70chevyc10
I have found what looks like the timing tab its not on the pass or driv side its right in the middle you can see it between the water pump and the block if you look stright down behind the water pump. is that an odd place for it and will it work there ?
