Old 10-15-2002, 02:17 PM   #1
SCOTI
SCOTI's Avatar
Dash Interchange?'s
Hey guys/gals I just purchased a 74 SWB/Fleet w/my insurance settlement $$ from my beater 68. It's a clean truck but the dash is seriously lacking. I was wondering if anyone had swapped a newer (say 82-87) dash in place of the older unit?? Anything I should know/look for? Any tips to make the swap go easier?? Thanks in advance.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-15-2002, 09:16 PM   #2
Hooter
My other Love
Hooter's Avatar
Just the pad or the whole thing, with the pad you shouldnt have any problems, with the cluster your only problem is the oil guage, in 74 the guage was mechanical (ie hard a hard line going right into it) but in 82 it was electric, you can change the guages out of anything between 73-77 with no problems, Whats wrong with your dash anyways? I like the 73-79 dashed better anyways
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 10-16-2002, 08:34 AM   #3
SCOTI
SCOTI's Avatar
The dash itself isn't actually that bad. The lower painted portion (red) is decent but the top half has typical fading/warping damage & the coffee color has got to go + the guage cluster is the 'woodgrain' laminate cover & I don't want that look for this truck. I was thinking of using some billet trim pieces on the dash ( painted to match the vinyl ) & if I'm not mistaken they won't work w/earlier style dashes. I'm not sure what I'll do w/the actual guages yet . . .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-16-2002, 02:35 PM   #4
78SilveradoSWB
78SilveradoSWB's Avatar
Dash pads do differ. 73-78 dash pads are the same, but 79-80 still the same but has cut out for VIN id tag. 81-87differ slightly with the trim panel curving outwards on the right side and I believe the dash panel area is not as angled as the earlier years.
78SilveradoSWB is offline   Reply With Quote
Old 10-16-2002, 05:11 PM   #5
SCOTI
SCOTI's Avatar
THanks for the input. I was considering using an 84-87 dash & prob swapping out the guages w/some aftermarket units. I'm not to concerned w/the notch for the VIN on the later dash cause it's in the corner & really out of direct line of sight.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-23-2002, 03:06 AM   #6
Duallie
Duallie's Avatar
'73-76 had an ammeter, 77 up had a voltmeter.
'73-'79 had a mechanical oil pressure gauge, 80 up was electric.
Just these few changes will mean your old wire harness won't work. But you can figure out what wires to rearrange in the dash plug and make it work. I've done it, but I had both the old and the new harnesses in front of me.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
Old 10-23-2002, 12:05 PM   #7
78SilveradoSWB
[QUOTE]Originally posted by Duallie
[B]'73-76 had an ammeter, 77 up had a voltmeter.
My 78 has a electric oil pressure gauge.
Old 10-24-2002, 08:14 AM   #8
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Why install the factory guages. Install digital guages or afermarket mechnical guages. I personnally have digital guages. Just follow the link on my signature to the "cab and instruments" page.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-24-2002, 11:05 AM   #9
SCOTI
SCOTI's Avatar
I'm still contemplating about the guages. Your digital set-up looks cool... but I'm undecided.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-29-2002, 11:06 PM   #10
swervin ervin
You get what you pay for
swervin ervin's Avatar
Sorry I'm late, but here is what I did to my gauges.
These are Autometer Procomps, installed from the rear of the bezel.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 10-30-2002, 11:44 AM   #11
SCOTI
SCOTI's Avatar
That looks clean. I did a similar set-up years ago in a 74 Z-28 I had. I used just regular autometer 'autoguages' back then. Maybe I'll play around w/something similar.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-30-2002, 12:13 PM   #12
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Mike you're killing me with those pics like that I want that setup so bad!! You seem to make everything look great.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
