01-04-2008, 11:33 AM | #1 |
heater core position
i changed out the heater core on my 69 gmc C1500 and was wandering which way the heater inlets went my truck never came with a core and i think the 3/4 inlet is on the top thank you
01-04-2008, 01:27 PM | #2 |
member #16
Re: heater core position
I think you are right.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
01-04-2008, 03:06 PM | #3 |
LWB Club
How was that whole job (installing a heater core)? I just found out today that mine is leaking. Never tackled this but gonna give it a try. Anyways, here's a bump for ya.
72 Chevy Custom LWB |
01-04-2008, 06:47 PM | #4 | |
I'm in agreement (3/4" on top).
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
01-05-2008, 02:47 AM | #5 |
Just did mine back in Oct. I didn't have to remove the hood hinge though. Just drop the inner fender down.
1997 GMC Sierra Ext 1965 Mustang |
01-05-2008, 02:57 AM | #6 |
blood type; Retumbo
in the 5/8 and out the 3/4. otherwise you will create higher pressure in the core leading to eventual blow-out. that is the way the engineers made them.
if you see a car with the same size on both then the feed has a restrictor inside. |
