Old 10-15-2002, 03:22 PM   #1
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Question....
Im waiting on a guy to call me back with an estimate on some work I need done on my Burb, and was wondering what y'all would consider a "fair" price and down time. Any and all opinions and guesstimates are appreciated.
My truck is a 71 GMC Burb, 4X4, 350/350, Rochester Quadrajet, and also have aftermarket AMA a/c set up...
I need to have the engine pulled and have a COMPLETE gasket change (engine resealed), Rebuild and tune the carb, and set the timming.
Sooo whatcha think???
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline   Reply With Quote
Old 10-15-2002, 03:26 PM   #2
Smooth68
Smooth68's Avatar
1 week and $500 - 600
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 10-15-2002, 03:53 PM   #3
dubie
dubie's Avatar
I would say 7-10 days for sure. But when you say rebuild, do you want the cranck pulled and have the cylinders honed and crosshatched? or do you just want a rebuild kit. The kit would include a set of piston rings and all the seal and gaskets to seal up the engine. If you go with the rebuild kit, then you down time will be about 7 days and a cost of 500-800 bucks. That's my best estimate, but i'm not some screw ball garage owner . good luck with the quotes Jodie
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 10-15-2002, 03:56 PM   #4
my new 72
faster, faster, faster
my new 72's Avatar
Well, it is a little tricky. A week at the most is what it should take down time. As far as actual work time , it will take a little more than a total of 10-12 hours, if it includes head gaskets, and is done properly. What is the hourly labor rate for mechanics around there?? Here it is between $100-125 per hour for auto mechanics, and $60-100 per hour for motorcycle mechanics. I think $500-600 would be a little low, and I would really question myself as to whether I would want them to do the job for that. There may be a reason that they would be that cheap, you know. Good gaskets are not cheap either, and make a big difference. I would have to say look atleast at paying $1000 total for parts and labor.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 10-15-2002, 03:56 PM   #5
jmil1974
Ain't we cute?
jmil1974's Avatar
Those estimates sound about right to me, and I live in TX. Just remember the old matrix: good, cheap, fast -- pick TWO.
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES!
FOR SALE $3900
jmil1974 is offline   Reply With Quote
Old 10-15-2002, 04:16 PM   #6
COBALT
COBALT's Avatar
Do you have blown head gaskets and leaking oil like crazy? or are you just leaking some oil? In other words why the complete gasket change? I would consider rebuilding the engine with all that you're planning to do.
I have oil leaks with my 350, so I've been resealing it as I go. Finished the intake and rebuilt the carburetor. Head gaskets are ok, so I won't be pulling the engine until I have a different one to drop in. All I have left is the oil pan, rear main seal, and fuel pump to reseal, and the engine is still in the truck. Of course the transmission is coming out to reseal it, and that's what will make getting to the oil pan easy, but I suppose if you have to replace head gaskets, well...
You might consider having the torque converter inspected too, and the front main seal on the tranny replaced as a matter of course. Fluid replacement, and new filter. That should be cheap with the tranny exposed....just a thought.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 10-15-2002, 04:29 PM   #7
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
No thanks to supposed "mechanics" who cared nothing about anything except the money I was paying them, my truck leaks from virtually every fricken seam, I just had the enine rebuilt about 30,000 miles ago and know that the machine shop did their part, its the rest of the rebuild that I got taken on. I have a pretty long journey to take in December with my daughter, and my truck needs to be in excellent running condition.
Still waiting on the quote, ill let y'all know when I get it,
thanks again.
Old 10-15-2002, 05:19 PM   #8
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
I think the writer of this post wanted to rebuild the carb, not the engine.
I see no reason to pull the engine to seal it. You might want to jack it up to pull the pan, but all other gaskets are just as easily changed while the engine is in the truck. Can't see paying any more than $50 plus the kit to rebuild your carb (why not do it yourself, it's fun!). If you do not have a head gasket leak, or an intake manifold leak, you should be able to change the rear seal, pan, timing and water pump, fuel pump and valve cover gaskets in a day at most if you are an amateur.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 10-15-2002, 05:28 PM   #9
Randy70C-10
Randy70C-10's Avatar
Re: Question....
Randy70C-10 is offline   Reply With Quote
Old 10-15-2002, 05:28 PM   #10
Maximum Overdrive
December 21, 2012
Damn and I thought the labor at $60 an hour was bad here!
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 10-15-2002, 05:56 PM   #11
Blue_71
Bloo
Blue_71's Avatar
i thought the $35-50 here was a bad price!! thats why i learned to do it i dont think it should take over a day, two at most on the gaskets.
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 10-15-2002, 06:10 PM   #12
weasel29gm
SLOW BUT SURE,BUT CLOSER
Whatever the price don't let the guy say you need this or that etc. And get it in writing!!!!!!!!! I would say around 400.00 tops.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 10-15-2002, 11:52 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Jodie...throw in a couple cans or orange paint, you KNOW you wanna...
