Just here to help
![]() Join Date: Jan 2002
Hydroboost ?
Does it really make a difference on the braking and where should i be looking for parts if i decide to go that way?I have put two new boosters on mine and it doesnt seem to change that fact that i just dont have good brakes,aka sometimes they work great but at times they kind of suck.....lol.About what can someone expect to pay for the hydro setup?i know it is probably out of my range but trying to get some ideas for stopping this beast.lol. thanx guys!
#2 | |
Re: Hydroboost ?
Re: Hydroboost ?
The biggest advantage of hydroboost is it doesn't depend on engine vac to operate.
I've driven two trucks with it and both have stopped really well empty or loaded. Fom your description what cam are you running? Do you have any vac leaks? Just thoughts off the top of my head. If you have good brakes with engine rpm more than idle and very little brakes at idle I would be inclined to think you may have either a vac. problem/ leak or to much cam to run a vac assisted brake system. I have already set my 70 up to use it. The most expensive part of the system is the booster. The master cylinder, power steering res. and hoses shouldn't be expensive at all. I would venture to guess that jkade is correct about 200.00 or less from a junkyard. They can be found in higher gvw 1tons, box vans, maybe some 3/4 tons. Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub Last edited by sick69; 01-04-2008 at 05:16 PM. |
Re: Hydroboost ?
running hydroboost on my truck need to get rear brake hardware i have been waiting for info on the disc brake kit from another board member.
i have used these guys for all my parts and info. contact Kelvin or Lance at PSC Steering Components. 817-270-0102 i installed hydroboost on my Br*nc* and i was kissing the steering wheel every time i braked. thought it was overkill at first then i hauled my trailer and had to make a quick stop......it was well worth it. i purchased a saginaw P/S pump from these guys that bolted right up to my original P/S brakets. Br*nc* brakes set me back about 400$ because i bought everything new and had others do the work(hoses). on the C-10 i am at about 235$ and that is a used hydroboost from ebay shipped 100$ and P/S pump brand new for 95$ shipped. |
Re: Hydroboost ?
i got hydroboost on my Grand Prix factory option because my car was originall a diesel it stops really well,
another plus is the size on the firewall instead of say a 10" around booster to build around you have a much more compact unit i'm going with a hydraulic clutch so i figure a hydro boost will help with the mounting
,Clint LOUD PIPES SAVE LIVES ![]() 69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA |
Just here to help
Re: Hydroboost ?
Thanx for the tips so far guys.I dont think mine should be anything to do with cam as i am just running the 265hp gm goodwrench stock so far.i have tried different boosters and i can not find a vac leak anywhere?
Re: Hydroboost ?
Also check the GM trucks/suburbans with the diesels. I found a couple set ups for $200 a while back. IIRC you will need the rod between the pedal and the master cylinder and it might be a good idea to get the steering box too because the fittings might be metric. You can find them with either a remote reservior for the power steering pump or one that is integral with the pump.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
![]() Join Date: Dec 2006
Re: Hydroboost ?
![]() Saw this one out in the self serve yard Saturday,1/2 price too. Actually I'm real pleased with my stock brakes. Maybe you should go into one of those big name places and get a free brake check,hear what they say.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
Overdrive club
Re: Hydroboost ?
I have never ran hydroboost till this one ton!!!!!And it rocks!!!!!!!!!!Very very smooth,id recommend it!!!!!!!!!!
1971 c-10 1951 3100 chevy 1970 chevy c-30 Sold! |
Tool Addiction=Money Shortage
Re: Hydroboost ?
It changed the way my pickup drives. I LOVE IT. I got my setup off an 80 chevy piano van
1967 K20 400TBI SM465/NP205 posi front, Detroit locker 4.56 rear |
Straight jacket required
Re: Hydroboost ?
Alright, post the pics, I have the setup waiting on install, but want to see how you've got yours.
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() |
![]() Join Date: Dec 2004
Re: Hydroboost ?
I dont know if there is a size difference but the local Pull a Part is full of Chevy Astro vans with hydroboost.
#13 |
Post Whore
![]() Join Date: Feb 2000
Re: Hydroboost ?
Here's a link to my detailed post of installing a hydroboost setup on my 69 K20 - I went from manual to hydroboost so the difference was incredible. I would highly recommend this swap.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#14 |
Just here to help
Re: Hydroboost ?
Thanx for all the ideas guys,time for me to start saving and looking
