Old 01-04-2008, 06:40 PM   #1
malexander44
steering column
I am putting in a tilt steering column from a mid 80s blazer and was wondering what I can do to cover the key hole and shift opening on the column. I plan on using the stock key (in dash) and mounting the automatic shifter on the floor.
Mark
malexander44 is offline   Reply With Quote
Old 01-04-2008, 06:45 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: steering column
You'd be way ahead to sell that column, and get one out of a 72 - 81 chevy/GMC van. They are very close to being a direct swap, and very few could ever tell it was not a stock piece.
the one you have has the issues you mentioned, and also it is larget in diameter too if i remember right.
Old 01-05-2008, 02:48 AM   #3
70GMCer
70GMCer's Avatar
Re: steering column
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-05-2008, 04:35 PM   #4
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: steering column
Check out this link for the correct tilt column you need.
http://67-72chevytrucks.com/vboard/s...teering+column
KevsClassics is offline   Reply With Quote
