01-04-2008, 07:23 PM | #1 |
Aluminum Fuel Cell Vent
I have a fuelcellguy tank that I am going to install. On the tank itself there is a slot for a vent. I have a motorcycle vent that I am planning to use for it but I need to know if I can get a elbow and thread it into the vent slot or would I need to run some vac line and move it away from the tank?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-04-2008, 07:48 PM | #2 |
Re: Aluminum Fuel Cell Vent
I have the same set up under the bed of the truck and I threaded in an elbow and ran some vent line through the chasis, I havent had any problems.
01-04-2008, 07:56 PM | #3 |
How did you run the vent? How far up or to the side did you go?
01-04-2008, 08:04 PM | #4 |
Questionable
i vented mine up and wire-tied it up to a bed support. many people say you need to have the opening be at least 1+ above the highest point of the tank, and I've heard people say "coil it around at least once" to prevent spillage.
here is a very big, very, very clear picture of how i ran mine. easy enough, right? http://satellitehead.com/gallery/dis...395&fullsize=1 FuelCellGuy makes some kick ass tanks. they look damned sweet when you slap some Line-X bedliner on them!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
01-04-2008, 08:30 PM | #5 |
Thanks for the pic shifty and yes fuelcellguy does make some kick ass tanks. Probably will be getting mine line-xed here in the next week or two after payday of course
01-04-2008, 08:33 PM | #6 |
Another question for you shifty regarding your sender wire. Did you run that up the pass side and then cross it over somewhere?
01-05-2008, 03:58 AM | #7 |
still buypickupparts
curious I have a tank build by FuelCellGuy and i was thinking to connect the vent line to my filler tube is this incorrect to do?
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
01-05-2008, 07:55 AM | #8 |
On my filler tube there is a smaller connection for a vent. So I am curious about the same thing.
01-05-2008, 07:59 AM | #9 | ||
Questionable
As you can see, I have three wires there: Blue: Fuel pump power lead (this goes to a relay for the LS1 wiring harness) Yellow: Sending unit lead (to fuel gauge) Black: Ground for the fuel pump (must have this) I grounded to the closest support brace. This may or may not have been smart, but I made sure it's getting good connection. For the yellow and blue leads, I zip-tied them together, ran them up the passenger's side framerail, then brought them up into the cab through the hole in the cab floor that was previously used by the stock fuel line (where the fuel line exited from stock tank and headed for the fuel pump in the engine bay). I used wire loom to protect the wires on their journey, and I think i zip-tied them to the brake line for security. I will probably punch a new hole in the cab floor when I finalize my wiring because I am not at all comfortable with how much open air there is between the framerail and where the wires go through the cab. When you have wires exposed for that long, you're asking for trouble. Punching a 1/4" hole in the floor just above the framerail would probably be perfect. Hope this helps!! Quote:
Calling him is probably a better bet than email if you're eager to get an answer quickly. He's a pretty busy guy and doesn't always seem to have a ton of time to spend emailing - and with the holidays going by and all of us trying to catch up, ..... Please let me (or us) know what FCG tells you. (Oh - so, vacuum would be created because ... you've got a closed tank that is capped with the gas cap. As the liquid gas is removed from the tank, there is no air coming into the tank to take the place of the gas, so ... suction begins. Think of it like a Capri Sun drink, or a box drink that you got in your lunchbox when you were a kid - when you suck the liquid out, the box crushes...)
01-05-2008, 08:15 AM | #10 |
Just an FYI.
The one's I bought didn't work right. I installed them first like the pic and then ran a little longer hose and tried them vertical. Drove the truck around and the tank still wasn't venting correctly. All I could figure was that the checkball on these things needs the abrupt movements that are created on a dirtbike to get the checkball to bounce to work correctly. Just my experience.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
01-05-2008, 08:17 AM | #11 |
ohh crap, um Shifty i didnt lookat it that way. I am not running a vented cap. so well I dont think I have Marks number anymore so I'll try ( I know you said PM wont be the fastest reply) but its all I got for now
01-05-2008, 08:54 AM | #12 |
Ok, now I have a question. Why not just use a vented cap? Sorry if im overlooking an obvious reason, I'm just a rookie with this stuff! But wouldnt slapping on a vented cap solve everything?
They sure don't make 'em like that anymore |
01-05-2008, 09:53 AM | #13 |
yes maybe a vented cap would work... but the cap Im using because I put my gas filler tube in the stake pocket of the box of the truck the body and cap I used are to apply on a boat. hence no vented cap so this is alarming me how the vent needs to be plumbed. I know I should have said this in the beginning but at that time I didnt think it mattered
01-05-2008, 10:05 AM | #14 |
Questionable
It's cool, no worries on the oversight.
Like I said - if Mark doesn't hit this thread, hopefully he'll hit you by PM. I might have his number or his email address floating around for you. I'll see what I can dig up.
01-05-2008, 10:16 AM | #15 |
thanks Shifty
01-07-2008, 04:15 PM | #16 |
Here is the way I ran mine.
I picked up the breather at the local Advance Auto, the bulkhead fitting from McMaster-Carr. I modified the anti-roll-over check valve to allow using 1/2" fuel line for the vent line. I made the bracket and bolted the whole thing way up between the inner and outer fender. I am running a sealed cap and filler snout from a RCI fuel cell. By the way, the stainless tank is from Rick's Hot Rod Shop and is for a 67-72 but I installed it in my 65. Why two sender units? One is for the stock gage. The other is for the LS2computer. (If it is worth doing it is worth doing to excess) TR65
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
01-08-2008, 08:24 AM | #17 |
TR65 thanks for that info. Do you have a part numbers for what you used?
01-08-2008, 09:41 AM | #18 |
Skokie,
Here is the vent info. The anti rollover valve came with the tank so I don't have any info for that. It was set up for 1/4" hose and I wanted less restriction (for ease of tank filling) so I converted it to 1/2". If you need filler info let me know. TR65
