![]() Join Date: Jan 2004
1972 Suburban Parts
I've got an accumulation of suburban parts that I won't be needing.
Front crossmember, stripped, powdercoated gloss black, not sure if it will ship via UPS or not. $25.00 Rear coils, stock height, like brand new. $50.00 for the pair. Front coils, stock height, big block, like brand new. $50.00 for the pair. Stock spindles 3/4 ton, powdercoated black, not new, origional stock. $20.00 for the pair. Complete set of lower trim, black, with all clips, brand new in box. $275.00. All parts will ship from South Houston, Texas 77587. I accept paypal. I'll try to post pictures tonight, I had some free time here at work so I decided to post the ad.
My Suburban Project 72 Suburban 68 SWB 57 Belair 55 Cameo 06 Chevy 1/2 ton crew 09 Suburban |
Suburban parts
Here's a link to some items I have for sale on the parts board.
http://67-72chevytrucks.com/vboard/s...d.php?t=272633
![]() Join Date: Aug 2003
Re: 1972 Suburban Parts
Interested in the trim,if it's for a Suburban.
It is for a suburban.
Where did you get new mouldings. I didn't know they were reproduced. The mouldings are new,correct?
The mouldings were bought new 3 years ago from Outback Truck Parts in Magnolia Texas. They are still in plastic sleeving and labeled. Some of the front pieces are interchangeable with a fleetside truck and are labeled fleetside. It is the rear half which is different, these are labeled suburban. As soon as I can find the cable for this camera, I will upload the pictures.
are these all 3/4 parts?
1972 GMC Sierra 1972 GMC Super Custom Suburban |
This is a half ton Suburban, and I bought half ton front end parts for it, when I went to install them, the spindles turned out to be 3/4 ton, the 1/2 ton tie rods basically fell into the tapered holes in the spindles. To make a short story long, the spindles are the only 3/4 ton part on this suburban besides the tie rod ends which are being used with dropped spindles on the truck.
Found the cable, heres the pics:
front and rear shocks
Front and Rear shocks off of my 1972 Suburban before rebuild. Appx. 200 miles on them. Ship from South Houston, Texas 77587.
Fronts: $15.00 for the pair. Rears with upper mounts: $25.00 for the pair.
My Suburban Project 72 Suburban 68 SWB 57 Belair 55 Cameo 06 Chevy 1/2 ton crew 09 Suburban Last edited by gregfull; 01-05-2008 at 04:11 PM. |
How much to ship mouldings to 30094?
uncle, sent you a PM.
#13 |
Interested in trim if Uncle passes.
#14 |
![]() Join Date: Feb 2001
I'll TAKE the trim if Tim passes!!
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
#15 |
stock suspension parts
Just in case someone over here needs some stock suspension parts.
http://67-72chevytrucks.com/vboard/s...d.php?t=272708 http://67-72chevytrucks.com/vboard/s...d.php?t=272633
#16 |
Re: front and rear shocks
I may be interested. What are the rear ones. I see the front are sensatrac, but what about the rear?
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#17 |
I believe they are O'reilly's house brand, not sure who made them for Oreilly though. Sorry.
#18 |
Payment sent. Thanks.
#19 |
Mouldings gone! Thanks Uncle.
#20 |
turbo enthusiast
Do you know if the 3/4 ton spindles would fit a '71 3/4 ton 2wd truck?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
#21 |
I don't see why they wouldn't. As long as the ball joints and tie rods you're running now are true 3/4 ton.
#22 |
turbo enthusiast
could you check the threads on the spindles where the caliper bolts up and make sure they are good? Do you take P.O.M.O.?
#23 |
I'll check the threads, if need be I'll bring a tap home from the shop and chase the threads. I'll send you a PM Monday regarding the threads. And sure, I'll accept a money order.
#24 |
Sorry for the stupid question but what makes the front springs for a BB>
#25 |
big block springs are going to be heavier and stiffer than a small block spring. For example, your half ton with a small block may sit a little higher and ride a little rougher with bb springs under it.
