Old 01-05-2008, 10:54 AM   #1
acl
acl's Avatar
what did you use for speakers
looking for ideas and examples of what you did for speakers and where did you put them. Not a lot of room in the 68 cab. Kick panels are the easiest sounding with brake and dimmer adj. but was interested in anything different. checked formum and some there but looking for more. Anyone not happy with kickpanel that come with speakers? Buy the panels add the speakers.
Thanks Gary
acl is offline   Reply With Quote
Old 01-05-2008, 10:58 AM   #2
clos69
Its Topless Season!!!!
clos69's Avatar
Re: what did you use for speakers
You might get more feedback if you post it in the truck audio forum....
clos69 is offline   Reply With Quote
Old 01-05-2008, 11:46 AM   #3
68GMC910
I put 6.5'' MTX speakers in my door, they sound great
68GMC910 is offline   Reply With Quote
Old 01-05-2008, 11:57 AM   #4
Orange
Licensed to Thrill!
Orange's Avatar
The general consensus on the board about the panels that you buy and put your speakers into is that you can't easily find a lot of speakers that fit. They have to be shallow mount 6-1/2"s. I also was going to have a problem with them clearing my e-brake. 1968 e-brake is under the dash though, right?
I have 2 NICE 6x9's under the seat and 2 6-1/2"s in some custom made kick panel pods.
You can find info for making your own kick panel pods in the FAQ (in my signature).
I also have the ones I made to print out a template for. They print out on 11x17 paper.
http://slickorange.com/board/driver.pdf
http://slickorange.com/board/passenger.pdf
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 01-05-2008, 12:05 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
I mounted 6" speakers in the panel just below the rear window and right beside the seat ends on my 72 Chevy 4X4.
I am going to install 4 X 6 speakers in the rear pillars of the 68 cab that I have and build forms for the 4 X 6 speakers to allow them to set in the dash behind the padded cover. Right now it has no glass or inner liners in it.
piecesparts is offline   Reply With Quote
Old 01-05-2008, 12:26 PM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
Can you please post pics? I'd love to see your install...sounds like a great idea. I'm not afraid to cut up my cab, either.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-05-2008, 01:03 PM   #7
69C10@16
I've got two 6x9's in the driver side door (haven't had time to do the passenger side yet) with some plastic covers behind them. The cover's really kill the bass response though. It won't be an issue though because I've got two twelve inch subs going in under the seat. I really like the way the 6x9's look and they really bring out the mid to upper range of the spectrum.
69C10@16 is offline   Reply With Quote
Old 01-05-2008, 02:55 PM   #8
piecesparts
I would, if I still had the truck. I sold many years ago. At the time( in the mid seventies), that I owned it, I had high back bucket seats in it, from a mid seventies Mustang and a center pedestal seat to make it a 3-way bench. The panel that is just below the window is real close to the size of a 6" speaker, and I cut it out to fit the speaker just between the seat back and the rear pillar. The panel is not overly deep, so the speaker does not need to have a large magnet on it. I also had 6" X 9" speakers in the lower door panels for a mid bass effect. If you remove the fuel tank from the cab, then there are many possibilites.
However, there are many upgrades to speakers on the market today and the sizes are smaller and more efficient. You can get a 4"X6" or a 5 1/2" round speaker that will fit the panel size much better. It does put the sound right at your ear and makes it more efficient on a truck with the windows down.
As I said, my present 68 Chevy truck project will have a 4"X6" speaker (just like what is in the early Nineties Chevy trucks mounted in the rear pillars (between the door frame and the rear window) and it will give the same effect as the later model trucks. There is plenty of room behind the pillar for a good magnet speaker and the sound reproduction should be good.
Old 01-05-2008, 03:53 PM   #9
bad68bowtie
On the college boy budget...
bad68bowtie's Avatar
I bought the prefabbed plastic panels a few years ago and I agree with the general opinion of them, they're not that great. It's kind of one of those things where they work and get the job done, but there's a lot left to be desired from them. I mounted 6.5 inch speakers in mine and I had to round the hole in the panel out to fit them in and then the panels were too shallow. Among those issues I also had to do some modifications just to get them to fit into the actual kick panel.
If I were to do it all over again (which I might sometime soon) I'd go the route of trying to make my own panels like what Orange posted.
-'68 C10 short/step- 350/350
bad68bowtie is offline   Reply With Quote
Old 01-05-2008, 03:55 PM   #10
icesickl
icesickl's Avatar
I am doing a frame mount fuel cell so I will put 2 12s behind the seat in my 67 and I plan on making a custom center console with a set of componants and mount the tweets in pods I will make on the dash.
You can also make a false glove box that only has a face and mount a small sub or a 4" speaker there and behind the guages firing down.
Drop it like its hot
icesickl is offline   Reply With Quote
Old 01-05-2008, 04:01 PM   #11
Wasted Income
Boosted Member
Thanks!
That is a fantastic idea! I've been tossing and turning at night trying to decide where to mount speakers out of the way...that's my prime path now!
Turbo diesel
Old 01-05-2008, 06:09 PM   #12
piecesparts
Thanks!
Don't forget to consider using a filler piece at the bottom, inside the pillar to close up the open area under the sheetmetal at the height just behind the door latch. This will give a fuller (less tinney) sound and make your speakers sound many times better. I would also look at blending into the dash a set of component speakers (tweeters and mid range combo) to get the frontal image effect.
The panels that fit onto the kick panels is a JOKE at best. They do not provide for enough backspace for a good sound and are usually in the way when you put your feet down there. Either open up the door bottom to a pair of 6 X 9 speakers or build a pod to mount to the door and put a decent 8" speaker there. I put a set of 8" speakers on my 84 GMC doors with 6" speakers in the middle of the door and a small tweet at the top of the door, It can be done.
I am following some of what Icesickl is doing with the 68, I am going to put in a sub box/console combo in my truck for a base effect. I am looking at an Isobaric design for a tight sound. There will be a front image, a back fill, and the base box for my system when I am done.
Old 01-05-2008, 07:06 PM   #13
heavy71chevy
heavy71chevy's Avatar
I reckon i did the redneck way but i used house speakers the kind with multiple speakers in the same box...you have to make sure they fit with enough cleareance you can adjust the seat still but that with a new speaker in the center sah and the xplod deck was plenty loud for my needs
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 01-05-2008, 07:11 PM   #14
whatnow123
whatnow123's Avatar
here is what i did...
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 01-06-2008, 02:16 PM   #15
mnunn454
mnunn454's Avatar
Currently in process, but am mounting two 12" subs behind the seats where the tank was, 6X9's in the door bottoms and will add supertweeters near the A-columns or below the wing windows. Undecided on 4.5"s in the kick panels.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 01-06-2008, 05:30 PM   #16
70' GMC
HERE.......Somewhere
70' GMC's Avatar
How about putting speakers in your glovebox
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 01-08-2008, 08:01 PM   #17
8696steve
Junior Member
8696steve's Avatar
I have the ones in the kick panels, and two behind the seat. They fit because the fuel tank in between the frame rails. here is the website. It is a good set up.
http://www.pioneerelectronics.com/PU...Speakers/Other
8696steve is offline   Reply With Quote
Old 01-09-2008, 06:08 AM   #18
Psycho71
Psycho71's Avatar
Yet another option. One I will be using myself. Old Dog Street Rods has a set of speaker pods w/map pockets that mounts to the doors. They are completely aftermarket, and universal. I'm actually ordering mine today, so I can't say yet how they actually look. I'll know more next week some time, when they arrive. I'll also be enclosing the rear pillars on my truck, and installing some speakers there as well. Not to mention the Sub box I'm building, and some tweeters up front (location yet to be determined). My main problem is figuring out where to ount all the amps and crossover. But i'm sure that'll work itself out too.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 01-09-2008, 12:32 PM   #19
76bonanza
76bonanza's Avatar
anyone tried on of these? looks like it would fit nice under seat.
http://www.crutchfield.com/App/Produ...3&tp=114&avf=N
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 01-09-2008, 01:51 PM   #20
clemson71guy
clemson71guy's Avatar
never seen one of them before, it looks pretty cool and its only 3 3/8" high it should fit under the seat.
i mite have to buy on of them.
clemson71guy is offline   Reply With Quote
Old 01-09-2008, 01:58 PM   #21
bfr57
bfr57's Avatar
I have 2 6x9s in boxes and a 6" (I think) tube woofer all under the seat. I'm using a Custom Autosound deck that I can hook MP3 into and an amp driving it all. Sounds really good!
bfr57 is offline   Reply With Quote
Old 01-09-2008, 02:20 PM   #22
sickred72
oh yeah theres room
sickred72 is offline   Reply With Quote
Old 01-09-2008, 05:15 PM   #23
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Sickred72 those kick panel speaks are kewl. Did you make em or buy em?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 01-09-2008, 06:38 PM   #24
Wasted Income
Boosted Member
Originally Posted by sickred72 View Post
oh yeah theres room
OMG!!! That panel under the back window looks fantastic!!!!!! WAY cool!
Turbo diesel
Old 01-09-2008, 07:33 PM   #25
whitesswj
Embrace the Redneck
whitesswj's Avatar
oh yeah theres room
Where did you get that back panel?
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
