Old 01-05-2008, 02:50 PM   #1
skokie
skokie's Avatar
4L80E instead of 4L60E
Ok for you guys that have the GENIII motors have anyone of you put in a 4L80E instead of the 4L60E and if so what did you have to do different in the install?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 01-05-2008, 03:58 PM   #2
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: 4L80E instead of 4L60E
Just swapped a '60 out for an '80 in my buddy's truck. Different crossmember, different converter, conversion flywheel (or a 4L80E flywheel with a crank spacer.) Wiring harness has to be changed around a bit too. Nothing major, and Speartech makes the conversion pieces for the harness. Lengthen trans cooler lines. Pretty easy swap, IMO.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-05-2008, 07:09 PM   #3
skokie
skokie's Avatar
Thanks for the info.
68 build thread
