How Wide Can We Go???????
I am wondering how wide a rear wheel we can throw under our trucks without modification. My stepside is lowered 7 in the rear and I have a set of 10" wide slot rims I want to run on the rear with some low profiles. What is the widest you guys are running?
Wheelin' and Dealin'
Re: How Wide Can We Go???????
well my brotehr can fit 10 inch wde street slicks under his 69 camaro then i imaginan we can
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside ![]() Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears ![]() ![]() my build thread: ![]() http://67-72chevytrucks.com/vboard/s...=1#post2601700 |
Still Truckless!
i have 265/60/R15's on my truck IIRC. I'll look tonight. they're on stock 8" truck rallies but stick out on the sides quite a bit. Dunno if that helps at all or not
~James ![]() ![]() 2009 Hyundai Sonata<~~Wife's sedanomatic 1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive ![]() ![]() ![]() ![]() |
Official Site Guitar Shredder
i have 17x13 rear wheels rubber is 355/40/17 tires are about a 1/2 from rubbing the bed
I will have to check my offset tonite. I know that pretty much will decide if they will slide up inside my fenders. I am sure it will be tight if it will fit at all.
Hey bad67 what kind of backspacing do your wheels have.
