Old 01-05-2008, 04:59 PM   #1
**grumpy**
**grumpy**'s Avatar
Arrow TA lowering block measurements...??
I can't get to my truck right now.
Can someone give me accurate measurements of those trailing arm lowering blocks?
I want to make some at work since I'm broke. That way I can just have some ubolts made.
Thanks in advance.
**grumpy** is offline   Reply With Quote
Old 01-05-2008, 05:19 PM   #2
Dadsredwagon
Dadsredwagon's Avatar
Re: TA lowering block measurements...??
I see them on the ccp website as 1.5 and 2 inch I can't find ubolts. good luck
Dadsredwagon is offline   Reply With Quote
Old 01-05-2008, 05:25 PM   #3
**grumpy**
**grumpy**'s Avatar
What I meant was, what is the length and width sizes, and exact bolt-hole location..?
Sorry I wasn't clear. I plan to make some out of 3/4" and 1" steel bars. i can stack them for desired drop.
Old 01-05-2008, 05:53 PM   #4
Dadsredwagon
no problem.... I made mine too, any luck on the ubolts, where too buy cheap , everything i find is $$$$
Old 01-06-2008, 05:34 PM   #5
**grumpy**
**grumpy**'s Avatar
I'm getting ubolts made at a local spring place. I don't have a cost yet. I wll let you know though, in case you'd like me to get you a pair and mail them to you.
Can anyone measure their blocks and give me the length and width, and the bolt hole locations???? Please
I would greatly appreciate it.
Old 01-06-2008, 09:02 PM   #6
Frizzle Fry
Frizzle Fry's Avatar
When I made mine I just went about 6" long and 3" wide. Then you know that the U-Bolts are for a 3" axle tube so you should be able to figure out where to put the holes.
Frizzle Fry is offline   Reply With Quote
Old 01-06-2008, 09:30 PM   #7
wild one
Registered.........
wild one's Avatar
Check this FAQ out : http://67-72chevytrucks.com/vboard/s...d.php?t=196457
When I made mine, i used the 2"x2"x1/4" steel tube as previously mentioned in the above write up. I made each block 7" long, drilled the holes at 4 1/4" apart on center (the u-bolts are 5" across and made out of 3/4" stock) and drilled the holes with a 13/16" drill bit.
I then had my new u-bolts made 11" long - factory ones are 8 1/2" long - by these guys : http://www.bettsspring.com/contact.htm . The pair cost me $30.00 with new nuts included ( this was an over the counter price but they do ship ).
Hope this helps,
Pete
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
