Old 01-05-2008, 05:13 PM   #1
bedsled71
bedsled71's Avatar
Anyone Z w/ engine still in?
wondering if anyone zed with engine still in and how difficult it was?
bedsled71 is offline   Reply With Quote
Old 01-06-2008, 02:42 AM   #2
jlaird
jlaird's Avatar
Re: Anyone Z w/ engine still in?
yes, I have seen pictures on here where people have done a z with the engine still in. IIRC, they said it wasn't hard, but I can not see how it would be easy, especially being able to access the inner frame rail to have room to properly weld. I would just do yourself a favor and pull the engine IMO.
jlaird is offline   Reply With Quote
Old 01-06-2008, 05:40 AM   #3
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
pull the motor, I did it with mine in and took it out to finish later.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 01-06-2008, 05:40 AM   #4
bedsled71
bedsled71's Avatar
the inner framerails is what i was worried about.. i would probably have to take the headers out to get to it.. i guess ill have to check it out. i have only 2 inches till i lay pinch in the front so im not going any bigger.. you think i will have any issues with the steering. maybe just notch the upper arm?
and did you put flat stock between the rails where you z'ed to makeup for the thickness of the sawzall blade?
Old 01-12-2008, 05:47 PM   #5
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
What exactly is Z ing? Offsetting?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 01-12-2008, 08:05 PM   #6
smbrouss70
smbrouss70's Avatar
Yeah, basically. I made this little diagram to explain it to my wife.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
