Old 01-05-2008, 05:40 PM   #1
70' GMC
HERE.......Somewhere
70' GMC's Avatar
Exclamation What the W means on the oil!!!
I read on a calender which is auto related, and it said that the "W" meant winter NOT weight. So if it says 10W or 20W it means 10 degrees in winter or 20 degrees in winter. I hope someone has some more info on this.
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 01-05-2008, 05:50 PM   #2
BarryB
BarryB's Avatar
Re: What the W means on the oil!!!
The lower the numer the easier it flows in the winter so a 5W would flow well in winter climate's. Thats my understanding of it. Now the latter part of oil identification 30 40 50. I have now idea.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 01-05-2008, 05:58 PM   #3
wibilly
wibilly's Avatar
i think the whole multi viscosity oil thery is a farse where i come from it all flows like 85-90 in the winter
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 01-05-2008, 06:02 PM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
This is from Wikipedia;
The API/SAE designation for multi-grade oils includes two grade numbers; for example, 10W-30 designates a common multi-grade oil. Historically, the first number associated with the W (again 'W' is for Winter, not Weight) is not rated at any single temperature. The "10W" means that this oil can be pumped by your engine as well as a single-grade SAE 10 oil can be pumped. "5W" can be pumped at a lower temperature than "10W". "0W" can be pumped at a lower temperature than "5W", and thins less at temperatures above 99°C (210°F). The second number, 30, means that the viscosity of this multi-grade oil at 100°C (212°F) operating temperature corresponds to the viscosity of a single-grade 30 oil at same temperature. The governing SAE standard is called SAE J300. This "classic" method of defining the "W" rating has since been replaced with a more technical test where a "cold crank simulator" is used at increasingly lowered temps. A 0W oil is tested at -30°F, a 5W at -25°F and a 10W is tested at -20°F. The real-world ability of an oil to crank in the cold is diminished soon after put into service. The motor oil grade and viscosity to be used in a given vehicle is specified by the manufacturer of the vehicle (although some modern European cars now make no viscosity requirement), but can vary from country to country when climatic or mpg constraints come into play.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 01-05-2008, 06:06 PM   #5
corn
Polymers are added to a light base oil(5W, 10W, 20W), which prevent the oil from thinning as much as it warms up. At cold temperatures the polymers are coiled up and allow the oil to flow as their low numbers indicate. As the oil warms up the polymers begin to unwind into long chains that prevent the oil from thinning as much as it normally would. The result is that at 100 degrees C the oil has thinned only as much as the higher viscosity number indicates. Another way of looking at multi-vis oils is to think of a 20W-50 as a 20 weight oil that will not thin more than a 50 weight would when hot.
Forgot, W stands for winter...
corn is offline   Reply With Quote
Old 01-06-2008, 04:53 PM   #6
70' GMC
70' GMC's Avatar
So if I change the oil in the winter, would I have to get 5W-30?
Old 01-06-2008, 04:57 PM   #7
panhandler62
Java Mechanic
panhandler62's Avatar
In North Carolina? Shouldn't really be an issue.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
