Old 01-06-2008, 05:22 AM   #1
meathead95
computer illiterate
meathead95's Avatar
how can you tell when you hae a bad brake booster?
my old one leaked when you hit the brakes so i replaced it. and now the pedal is REAL hard and the brakes arent that great? the truck has new calipers, pads, brake shoes, and wheel cylinders. any ideas?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 01-06-2008, 06:11 AM   #2
71 super
71 super's Avatar
Re: how can you tell when you hae a bad brake booster?
I had one that did the same thing. There was some problem with the diaphram, replaced it and they startd working correctly. When motor has been running then shut off, if you pull the check valve out of the booster is there a sound of vaccum escaping? If not the diaphram is not working correctly and needs to be replaced. Hope this helps.
71 super is offline   Reply With Quote
Old 01-06-2008, 07:48 AM   #3
mbgmike
A hard pedal is one symptom of a bad booster. if you think about it. You have a spring assisted Diaphram thats using vacuum to pull it. If you lose vacuum or the booster diaphram is leaking it is now harder to push
mbgmike is offline   Reply With Quote
Old 01-06-2008, 08:01 AM   #4
meathead95
computer illiterate
meathead95's Avatar
i have good vaccum and i cant hear it leaking that is what made me wonder.
72 2wd blazer
72 swb 4x4
Old 01-06-2008, 08:50 AM   #5
72lb4x4
With the engine off, step on the brake pedal and start the engine. The pedal should be hard with the engine off and then sink a bit when the engine starts.
72lb4x4 is offline   Reply With Quote
Old 04-09-2008, 09:26 PM   #6
68 50th
68 50th's Avatar
I have the same problem with a very hard brake pedal. Good vacuum, no leaks and I can clearly hear the vacuum escaping when I pull the check valve.
I have had both the master and booster out of the truck for cleaning and painting, could I have missed a gasket or something when I was putting it back?
Mats..
1971 Cheyenne Super Custom Camper 475CBB/TH400/AC
1992 Silverado Sport Truck
1988 Silverado 2500 Ext Longbed 4x4
2001 GMC Sierra SLT 4x4
1990 Chevrolet K3500
1965 Pontiac Grand Prix
1980 Z 28 350/4-speed/AC/T-top
1980 Camaro Coupe V6/3-speed
1979 Buick Century Wagon
68 50th is offline   Reply With Quote
Old 04-09-2008, 10:10 PM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
If the pedal sinks when you start the truck, does that mean the booster and brakes are working properly?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-09-2008, 10:28 PM   #8
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
http://www.classicperform.com/TechBo...tm#testbooster
This link helped me alot with braking issues. No offence, just a review of the basics.
jayharrell is offline   Reply With Quote
