Old 10-15-2002, 07:42 PM   #1
muscletruck
drop leaf springs???
does anyone know where i can get some? i ve seen 4 inch drop springs for about 300 some dollars....anyone know where i can get some any cheaper...if not i will end up doing a flip kit, i just dont want to do the whole c-notch thing....thanks all
i think i found me truck!
78 Crew Cab Dually
454/TH400, Dual Flows, Edelbrock Intake, Cam, Lifters, Billet Grill, K&N Airfilter, Grant Steering Wheel, A/C, soon to be power windows and locks, lots of plans for this...
....gas prices go down please
muscletruck is offline   Reply With Quote
Old 10-15-2002, 08:50 PM   #2
my new 72
faster, faster, faster
my new 72's Avatar
I know one of the vendors on the board sells them. I think it is gmcpaul. Personally I wouldn't do a flip, take the time and do the springs. If money is an issue, then save for a bit longer and do it right. Don't rush and do a half a$$ed job you will regret later.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 10-15-2002, 09:36 PM   #3
canso
I had my springs de-arc'd 3 inches. They measure the lift from the centre of the eyes to the top of the main leaf. It makes your springs about a 1/4 inch longer which centres the springs in the wheel well better.
canso is offline   Reply With Quote
Old 10-15-2002, 10:47 PM   #4
muscletruck
doing it right?
how do yo lower the rear the correct way? de-arcing?....shackles?....what?....where do you take the springs to get de-arced? and how much does it cost?
78 Crew Cab Dually
Old 10-16-2002, 09:32 AM   #5
crazy longhorn
Fabricate till you "puke"
I did a flip on the longhorn, using direct connection spring saddles,& had a new set of u bolts made to accept a set of ford pu plates. the spring mount brackets were then knocked off the frame & moved down 1 1/4" to give roughly a 5" drop. this mod involved a little welding, & grade 8 bolts/pinch lock nuts for the spring mount brackets(7/16"). At the rear, I beefed up the hanger brackets by adding a short pc of 3x3x1/4 angle(bolted to the bottom of the frame,& the insides of the hanger). I also added a set of slapper bars to handle wheel hop. this wasnt the easiest route to take,but cash wise about $100 in parts & hardware. good luck.....crazy AL
crazy longhorn is offline   Reply With Quote
Old 10-16-2002, 02:31 PM   #6
Mike C
Mike C's Avatar
If you go Crazy Longhorns route, make sure on what size springs you have. IME, the Longhorns have the same leaf springs that the 4x4 had, they are 2 1/2" in width. The other 2 wheel drive trucks (at least half and 3/4 ton) have 2 1/4" wide springs. Eaton Detroit spring can build you new springs and you can have them de-arched at the same time.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-16-2002, 05:14 PM   #7
my new 72
my new 72's Avatar
the right way do do a four inch drop in the rear with leafs is to save and buy new springs. If you wanna go a little lower get shackles, but if you go the extra drop with the shackles, a c-notch will be required, and I just don't like notches. Here is a pic of my truck with 4 inch drop leafs and 2 1/2 drop spindles on 17x8 1/2 with 255/55/17 nitto rubber.
Old 10-16-2002, 05:18 PM   #8
Ackattack
Ackattack's Avatar
I just removed one of the middle springs to lower mine. I realize this isn't the proper way to do it, but it cost a total of $20 (new u bolts). I would think that if you got lowering shackles, that would probably be the best economical way to do it.
Luckily I don't really haul anything in my truck, so it's capacity isn't really an issue. I to think that I'm having issues with axle wrap, but I'm planning to get some traction bars to help with that issue.
Ackattack is offline   Reply With Quote
Old 10-16-2002, 05:23 PM   #9
my new 72
my new 72's Avatar
For some reason it won't let me post the pic. Send me you email address and I' send it to you that way.
Old 10-16-2002, 05:39 PM   #10
crazy longhorn
Mike C brought up a good point there......the direct connection saddle mounts are 2 1/2" wide, just like the longhorn spring. I hadnt thought about the 1/2 ton spring being 2 1/4" wide. Its too bad nobody offers a front hanger along with a shackle......I did a 2/4 drop on a 90 GMC with bell tech parts.......slick as hell! I also dont like notches, & dont have one......the final drop on my longhorn was on the body.......3/5 suspension, + 1 1/2" on the body& nothing scraps on the road, not even the full lenght headers! good luck.....longhorn
