Old 01-06-2008, 01:35 PM   #1
mothertrucker424
mothertrucker424's Avatar
cadillac clip
i am looking at buying a crashed 02 silverado needs a front clip can i use parts from a 02 escalde? or would it be better to get a silverado clip
p.s.-i'll be using junkyard parts too
mothertrucker424 is offline   Reply With Quote
Old 01-06-2008, 03:56 PM   #2
odie82
odie82's Avatar
Re: cadillac clip
you can buy the hole thing right here, beats searching for parts
hood-fenders-grill-
http://www.stylintrucks.com/parts.as..._prod_ids=2195
1982 chevy C-10, blue 2wd shortbox
17x9 cragar ss rims, 350V8-th400
2003 suzuki gsxr 1000-hit 175mph!!!
yeah it's fast-no you can't ride it
odie82 is offline   Reply With Quote
Old 01-06-2008, 04:44 PM   #3
mothertrucker424
Re: cadillac clip
for 2500-3000 without a core support and inner fenders or 250-300 junkyard for everything but thanks for the input does anyone know if its a bolt on from junkyard or does anyone know if a 03-up clip will fit??
Old 01-06-2008, 07:28 PM   #4
ostncoln
ostncoln's Avatar
Re: cadillac clip
i did this on my 2000 silverado. if you are buying the whole front clip off of the escalade it will all bolt up you will just need to lenghten the headlight wiring if the factory truck wiring is still there. the problem you will run into is the fenders and wheel flares/molding. on the 02s the fenders did not have any skin on them from the lower bodyline down and had 3 recesed bolt holes running across the wheel well. on mine we cut the bottom skin off of a p/u fneder and put it onto the escalade fender. on the later model escalades the flare/molding is part of the fender and would not match up with the rest of the body unless youadded that modling to the truck. i think the kits thay have now come with fenders that are ready to bolt on and to mod is needed. you might check and see if you can order just the fenders from a kit and buy salvage for the rest or just do like i did
here is a pic of the finished
1971 C-10 Project
350/400
5/7 drop
My Slow Build Thread
ostncoln is offline   Reply With Quote
Old 01-07-2008, 02:26 AM   #5
mothertrucker424
Re: cadillac clip
[QUOTE=ostncoln;251673 the problem you will run into is the fenders and wheel flares/molding. on the 02s the fenders did not have any skin on them from the lower bodyline down and had 3 recesed bolt holes running across the wheel well. on mine we cut the bottom skin off of a p/u fneder and put it onto the escalade fender.[/QUOTE]
could i weld up the holes or mud them ??
Old 01-07-2008, 03:48 AM   #6
ostncoln
ostncoln's Avatar
Re: cadillac clip
yeah i guess you could its just a pain b/c where they are dont follow the curve of the fender there is a recessed flat area around them. i looked for a picture of what i am talking about but cant find one. i used to have a cd with the pictures from doing the conversion on it but i cant ever find anything since i got married. so if you know of one at a junk yard, go look at it and see what you think. oh and another thing i though of is i dont know if aftermarket parts are different. i used GM stuff on mine
1971 C-10 Project
350/400
5/7 drop
Old 01-07-2008, 04:02 AM   #7
ostncoln
ostncoln's Avatar
Re: cadillac clip
actually you can almost see what i am talking about in that kit picture
and i found another picture that you can see where there is no skin on the bottom and the other hole. there may be just 2 instead of three
1971 C-10 Project
350/400
5/7 drop
Old 01-07-2008, 11:04 AM   #8
kevinr1970
Re: cadillac clip
From the Stylin' website:
"Minor welding is required. The lower section of your existing fenders must be cut off and grafted to the Escalade fenders for proper fit and cladding trim holes must be filled."
I don't think I would ever do this to my truck, but yours looks really sweet!
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-07-2008, 04:22 PM   #9
mothertrucker424
Re: cadillac clip
that sounds like to much work for a beater truck but will 03-up frnders bolt on?? and how is stylin concepts gonna sell a bolt on kit if you have to cut your old fenders
Old 01-07-2008, 08:00 PM   #10
ostncoln
ostncoln's Avatar
Re: cadillac clip
i think some of the places that have these kits now have fenders that you dont have to modify. the later models have the wheel flares and lower cladding stamped into the skin so they wouldnt match up at all. i dotn know what year they started doing that though.
1971 C-10 Project
350/400
5/7 drop
