Old 01-06-2008, 03:44 PM   #1
DavesRide
DavesRide's Avatar
Question 2nd Gen Camaro spindles for Lowering?
A friend of mine told me that second Generation front spindles would fit my 67 and drop it 2 or so inches. It required enlarging either a tie rod hole or ball joint hole. Has anyone ever tried this or should I be looking into the search button further? I read the "cutting the springs" thread last night and it got me to thinking about doing just a little of both to get it down and not be uncomfortable to drive around my bumpy town and nearby highways.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 01-06-2008, 04:22 PM   #2
scatesracing
Machinist
scatesracing's Avatar
Re: 2nd Gen Camaro spindles for Lowering?
I have heard that before but keep in mind that the wholes are tapered and you will need a taperd reamer or some other way to make the whole larger.... I just cut my springs and the snubbers on mine.rides good.... i put a pair of drop control arms on for a guy. that is the way to go IMO it road great and set lowwwwwww
scatesracing is offline   Reply With Quote
Old 01-06-2008, 04:28 PM   #3
68 short step
i tried this, i own a 76 firebird..and yes with a taper balljoint reamer they would fit, but they dont have the stops like the truck spindles do.....also i beleive the bearings are diffrent, so you'ld have to run a second gen. rotor ( this means converting from a 5on5 bolt pattern to a 5 on 4 3/4)
IMO just buy a set of 2.5 drop spindles for your truck for about 250 shipped..
68 short step is offline   Reply With Quote
Old 01-06-2008, 04:58 PM   #4
DavesRide
DavesRide's Avatar
I am just checking out possibilities right now. It is more crooked than a dogs hind leg in all facets right now but I would like to get it settled into a nice driving truck untill I can unleash some funds on it. Thanks.
