01-06-2008, 05:04 PM | #1 |
HERE.......Somewhere
What is the very best inline fuel filter???
The fuel filter is from napa but not sure who the manufacturer is, it is see through. The fuel filter has been on for almost a year. I looked around autozone, and advance autoparts, they had one called spector, specter something like that, then they had another one by mr. gasket. Is there one that has the replaceable filters. I want the very best, not some cheapo kind either.
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
01-06-2008, 05:26 PM | #2 |
Re: What is the very best inline fuel filter???
i just go to advance auto and get a plastic see threw one pay 4 buxs for it and call it done
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
01-06-2008, 05:34 PM | #3 |
Not enough info for safe response from questionable crazy @ss members that don't ven use seethru filters.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched |
01-06-2008, 05:39 PM | #4 | |
you can see the fuel filter in this pic
01-06-2008, 05:53 PM | #5 |
Born Psycho
those filters are an accident waiting to happen, they cause engine fires. if you decide to use one be sure to keep a very close eye on the rubber hoses and replace them often.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
01-06-2008, 05:59 PM | #6 |
You went from a Qjet to another? What did you do with the Qjet? I would like one. The filter can be any where! Put it between tank and pump. Put it between the pump and the carb. Unless it is stopped up it wiil let gas through. Get rid of that filter on top of your engine! FIRE O NO! Unless it is in the Qjet or another tightly sealed line. NO PLASTIC SEE THRU FUEL FILTERS ALLOWED, PLEASE.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched Last edited by DavesRide; 01-06-2008 at 06:04 PM. Reason: SAFETY REASONS BY PHYSICS AND NOT MY REASONING |
01-06-2008, 06:38 PM | #7 | |
01-06-2008, 06:45 PM | #8 |
72 Chevelle Club
Buy a steel inline filter and you wont have to worry about it breaking and causing a fire ,also keep an eye on your rubber hose in case of cracks.
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
01-06-2008, 06:49 PM | #9 |
72 Chevelle Club
Take the numbers off the chocke horn on the top of the carb to the parts store and they can tell you what size it is . Looks like a 600 holley from your pic. If you give me the numbers off it I can tell you what size it is also!! Please don't run a plastic or glass fuel filter I hate to see truck fires !!!!
01-06-2008, 06:50 PM | #10 |
Firefighter
Been using that kind of filter for years, NEVER EVER had any problems out of any of them!! Wix makes the filter in your pic, they also have a metal version I have used it for years also NAPA #3033. The clear one you have is #3003.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
01-06-2008, 06:52 PM | #11 | |
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! Last edited by 70' GMC; 01-06-2008 at 06:53 PM. |
01-06-2008, 06:58 PM | #12 |
Get the steel can type from Napa. You can wrench down pretty hard on the clamps without collapsing the inlets/outlets without leaks.
01-06-2008, 07:01 PM | #13 |
72 Chevelle Club
Yes Holley makes a kit for it . All you need is the number off it . The only thing to look for is excessive wear in the throttle shafts . If it's a 600 and yours are bad let me know I have a base plate with good shafts you can have for shipping costs !!
01-06-2008, 07:04 PM | #14 |
I asked a guy that goes to my job, he said 100 to rebuild plus 45 for the kit. What comes with the kit???
01-06-2008, 07:10 PM | #15 |
Firefighter
Gaskets,needles,seats,power valve, pump diaphram, and a few other parts.
01-06-2008, 07:19 PM | #16 |
They are actually in the carb, but if you use a flashlight and a mirror you can count them without taking apart the carb.
Seriously, just get the numbers off the carb and cross reference to Holley's site. They have a lot of good tech info there. Also, a good steel inline filter worked for me when I had rubber fuel line, until I switched to a AN braided line. Now I have an aluminum inline filter from Summit.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
01-06-2008, 08:19 PM | #17 |
Lemme show you something!!
Regarding the original Fuel Filter question I'll be running an aeromotive canister type in front of a holley blue pump, once I retrofit my fuel system. Barry Grant has also just come out with a mini-cartridge type filter that looks pretty trick too.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") Last edited by Dingfodgy; 01-06-2008 at 08:26 PM. |
01-06-2008, 11:00 PM | #18 |
like the Racor 1000 series. http://www.starmarinedepot.com/Racor...el+Filter.html
its better if you can fit a marine multi filter system so if one clogs, you can switch to the other one while you put a new element in the first filter without shutting down.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars |
01-07-2008, 03:26 AM | #19 |
Official Site Guitar Shredder
forget the plastic or glass see through filters..PERIOD ..i have seen those leak ,crack and the glass one s break many times...this is from personal experience also....buy a metal fuel filter ...call it done ..but you could run any see through filter you want, there is lots of wireing diagrams on here for you. ................for the fire those filters will cause.........
01-07-2008, 04:02 AM | #20 |
I run a plastic see through inline NAPA/Wix filter hadnt had a problem. Only time I had a truck fire was due to a leaking Holley carb (was leaking around the front fuel bowl even after rebuilding the carb) as soon as it warms up Im going to go to inline metal filter before the pump and a new rubber 5/16 line made for fuel injection (If it can handle the 45 lbs and up pressure of a fuel injection unit, itll dang sure handle the 5-8 lbs of pressure for the carb). Just my 2 cents.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." [Cherokee saying] 2001 Dodge Ram Sport 1500 4x4. (old ride) 1987 GMC V1500 Sierra Classic ("new" ride) |
01-07-2008, 04:04 AM | #21 |
oh the drama
Alex 1971 Lil' Red 350 SBC 700R4 |
01-07-2008, 05:48 AM | #22 | |
01-07-2008, 06:20 AM | #23 |
I think this is the carb numbers: 34R-10880B, it was the only numbers and letters I can find, it was on the passenger side.
01-07-2008, 09:01 AM | #24 |
The best filter is one between the tank and the fuel pump where it is not under pressure from the pump. If it leaks, it is not near the engine. But, some will insist on ease of install and gamble on it never leaking above their exhaust manifold---hummmm.
01-07-2008, 10:22 AM | #25 |
PROJECT 7DEUCE
Get a mason jar and a roll of tolet paper..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
