01-06-2008, 07:25 PM | #1 |
6L80E swap
Has any one thought about putting a 6l80e behind a gen III motor swap. It sounds kind of cool to have 6 gears. I thought of puting a lq9 and a 6l80e into my 67 c10.
01-06-2008, 07:27 PM | #2 | |
Boosted Member
Re: 6L80E swap
Also, to my knowledge, at this time there are no stand alone 6 speed controllers available at this time. I'd be all over it, otherwise!
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
01-06-2008, 07:46 PM | #3 |
Re: 6L80E swap
i beleive a E38 PCM and the TCM for that trans will work just fine...im currently talking to a customer of mine about this trans....its not a huge pain, like mentioned, but will require some computer and tuning knowledge...also john at speartech, makes a harness for just this, i think its 750$ well worth the $ if you dont wanna fool with anything..
01-07-2008, 10:40 AM | #4 |
Boosted Member
Re: 6L80E swap
The E40 was used on LS2 motors with the 24X reluctor, vs. the E38 LS2 engines with the 58X reluctor.
You'd need to either use an E40 set up for 24X or swap reluctor wheels on the LQ9.
01-07-2008, 12:55 PM | #5 |
Re: 6L80E swap
Orrrrr, you could get some more 710 for your flux capasitor and simply bypass the hooter with a dial barometer...Sheesh, you guys shoulda asked me sooner...
93 Sonoma 2.8/5spd 75 Malibu Classic 350/350 If it don't have round headlights and a carb, I don't trust it! Last edited by jrb71c20; 01-07-2008 at 01:02 PM. |
01-07-2008, 01:01 PM | #6 |
Re: 6L80E swap
Just yank the whole drivetrain out of a wrecked 07+ 6.2L denali or caddy. 400HP and 6 gears
If GM would ever get off their ass and offer the 6 speed on the 4.8 and 5.3L 1/2 ton trucks and SUV's, it would be a lot easier. It was supposed to be on the '08's but it's been pushed back to '09.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 01-07-2008 at 01:02 PM. |
01-07-2008, 01:49 PM | #7 |
Re: 6L80E swap
only a fellow okie from claremore, can make it so simple for us...
01-07-2008, 01:53 PM | #8 |
Re: 6L80E swap
Harrol 1968 SWB 1968 SWB 4x4 1969 Suburban 1970 LWB 1970 Blazer 2002 Tahoe Inside every older person is a younger person wondering what happened |
01-07-2008, 02:28 PM | #9 | |
Re: 6L80E swap
Amen, brother!!!
93 Sonoma 2.8/5spd 75 Malibu Classic 350/350 If it don't have round headlights and a carb, I don't trust it! |
01-07-2008, 03:47 PM | #10 |
Re: 6L80E swap
Speartech LS2/6L80E swap!
That was a good read! Speartech even states that a 69 C10 would be the perfect platform for this swap! Kevin LFD Inc. |
01-07-2008, 04:22 PM | #11 |
Re: 6L80E swap
01-08-2008, 12:29 AM | #12 |
Re: 6L80E swap
Anybody know what the gear ratios are on the 6 forward gears?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
01-08-2008, 09:49 AM | #13 |
Re: 6L80E swap
6L80E
Type: Six-speed RWD / AWD, electronically controlled automatic overdrive transmission with torque converter clutch. Clutch-to-clutch architecture, with integral Electro / Hydraulic Controls Module Maximum engine power: 413 bhp (308 kW) Maximum engine torque: 430 lb-ft (583 Nm) Maximum gearbox torque: 664 lb-ft (900 Nm) Gear ratios: MYC First: 4.03 Second: 2.36 Third: 1.53 Fourth: 1.15 Fifth: 0.85 Sixth: 0.67 Reverse: -3.06 Maximum shift speed 6500 rpm Maximum validated weightstarget ) GVW: 8600 lb (3901 kg), GCVW: 14000 lb (6350 kg) Case description: Three-piece ( Bell, main, extension) Case material: die cast aluminum Shift pattern: (2) Three-way on / off solenoids Shift quality: Five variable bleed solenoids Torque converter clutch: Variable Bleed Solenoid ECCC Converter size: 300 mm ( reference ) Fluid type: DEXRONŽ VI Fluid capacity: w/ 258 & 300mm converter 258 mm: 9.7 L (8.22 kg), 300 mm: 11.9 L (10.1 kg) Transmission weight: w/ 258 & 300mm converter 258 mm: Wet: 94-96 kg (207-211 lb) 300 mm: Wet: 102-104 kg (225-229 lb) Pressure taps available: line pressure Assembly site: GMPT Ypsilanti, Mich. Applications: Chevrolet Corvette Cadillac XLR Cadillac XLR-V Cadillac STS-V GMC Yukon Denali GMC Yukon Denali XL Cadillac Escalade Cadillac Escalade ESV Cadillac Escalade EXT http://wheeltalk.fancal.net/?p=358
01-08-2008, 10:21 AM | #14 |
Re: 6L80E swap
Thanks!
Man, that's a steep first gear! You could run a 2.73 rear gear and still launch harder than a 4.11 with a TH400! And with 6th gear still have a similar ratio as a T-56 with a 3.73! But with such a wide spread between first and second gear it would be worse than a 700-r4. You would launch, then bog unless the engine hooked up to it has a W-I-D-E torque curve.
01-08-2008, 06:22 PM | #15 |
Re: 6L80E swap
Thats the set-up I would like to have, all stock for a daily driver. Whenever someone gets this installed in a 67-72 I would like to know what all you have to get and where to get it.
01-09-2008, 04:08 AM | #16 | |
Re: 6L80E swap
A Sierra Denali would be a neck snapping rocket with a 4.10.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 01-09-2008 at 04:12 AM. |
01-09-2008, 08:24 AM | #17 | |
Boosted Member
Re: 6L80E swap
