01-07-2008, 01:42 AM | #1 |
It Is What It Is,,,,
Adding a tilt
I got a TILT column. The ignition switch, Can I use the one thats on mine now or do i have to get a new switch for the tilt? And is there any other changes I need to do?
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
01-07-2008, 04:18 AM | #2 |
Re: Adding a tilt
You should have no problem using your old switch. I just did this last year.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
01-07-2008, 05:27 AM | #3 |
Robert Olson Transport
Re: Adding a tilt
its all direct bolt in replacement the ignition switch ( key ) and the column should swap in no problems
01-07-2008, 07:55 AM | #4 |
Re: Adding a tilt
do you mean the key switch, or the ingniton switch down the column a ways, the one on the column is no prob. the key switch is a bit more, thats where I got held up on mine, you have to have special tools to release the spring clip and then their is a lot going on in the column. I found some one to do it for 75 bucks and I put my old one back in till I have time to get the tilt to them, good luck bob
01-08-2008, 07:58 AM | #5 |
One shot, one kill.
Re: Adding a tilt
Mr79: Ign lock cyl and ign switch are two different parts. Changing the switch is no problem, especially with the colunm out, unless you drop the high beam rod out of the pocket it rides in under the signal light switch. Changing the lock cyl is an entirely different critter. You do need special tools (lock plate compressor and wheel puller) This isn't something a novice should attempt. On colunms like this (round colunms, not the square ones) there are 4 reverse head torqs screws at the bottom that often loosen up and you may not find out they are loose until you have swaped out the colunms due to spring pressure within the tilt mechanism holding it tight until you give it a real good pull. If this is the case try to find someone locally to fix it properly. If you can't find anyone in FL to do it for you, ship it up here and I'll fix it for you and ship it back with a new lock and keys. I have over the years accumulated enough parts to build a whole colunm from scratch. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
01-08-2008, 08:26 AM | #6 |
The One And Only !!!
Re: Adding a tilt
Dang.....Are they supplying the vaseline ? That's all of a 15/20 minute job with the proper tools ! A lot of auto parts stores offer the puller and lock plate tools for loan free of charge.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
