Old 01-07-2008, 06:22 AM   #1
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Transfer case ID
Can anyone tell me how to identify which transfer case I have in my Blazer?
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 01-07-2008, 06:26 AM   #2
1969k10stepside
Re: Transfer case ID
If it's stock it'll be a NP205.It'll look like the one below (mine)
1969k10stepside is offline   Reply With Quote
Old 01-07-2008, 06:41 AM   #3
Chevyman63
Chevyman63's Avatar
Thanks 1969k10stepside, I knew I could count on you guys and it only took 4 minutes for a response. Thanks again.
BTW, mine is definitely an NP205.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 01-07-2008, 07:06 AM   #4
Critter
Future TOTM Winner
Critter's Avatar
The little circular cover in the middle with 3 bolts gives it away that its a NP205. That't the easiest way to make a quick ID IMHO
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-07-2008, 07:28 AM   #5
Chevyman63
Chevyman63's Avatar
Thanks Critter, I'll remember that.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 01-08-2008, 03:29 AM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
But remember the Rockwell T221 also has that little cover - I thought I had an NP205 when I first got my K20 after seeing those three bolts and cover
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-08-2008, 04:06 AM   #7
Chevyman63
Chevyman63's Avatar
Thanks YJ, also good info.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 01-08-2008, 08:55 AM   #8
Critter
Future TOTM Winner
Critter's Avatar
true, I guess I should say the "FLAT" cover with 3 bolts... You have a good point.
Old 01-09-2008, 01:33 AM   #9
69TowRig
Not always the case. If it was stock with a 3-speed column shift it has a Dana 20 like mine does. NP205s came with the other transmissions.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 01-09-2008, 07:52 AM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
And just to throw in some more confusion, my 70 K5 with a 4 speed originally had the Dana 20.
Old 01-09-2008, 10:38 AM   #11
1969k10stepside
I think the older ones had the Dana but by 71 or so they had the NP205 with auto,manual,or 3spd.
