Old 01-07-2008, 11:40 AM   #1
powell72
powell72's Avatar
Rear sway bar installed
I got around to installing the rear sway bar I got for Christmas. It's a 7/8'' Hellwig from Brothers, they where having a sale and they were $99. I wasn't really expecting as much of a difference as there was. I would recommend one. I also put poly bushings on the front bar while I was at it. I found two holes to mount the end link brackets from instead of drilling holes, they're right below the bed mount brackets on both sides. They're 5/16'' holes that I just opened up to 3/8''. The bar and hardware was a gold color so I painted the bar, sleeves and end link brackets with semi flat black.
It's already dirty from driving home on slushy roads.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 01-07-2008, 11:44 AM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Rear sway bar installed
Cool! I'm planning on adding one to my '69 C10. I'm glad to hear its worth doing the mod.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 01-07-2008, 12:33 PM   #3
That`s nice.I`d like to use one on my shortbed.
Old 01-07-2008, 01:33 PM   #4
ChevyDude
I got one on Lil' Red...Looks good Chris!!!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 01-07-2008, 01:48 PM   #5
whatnow123
whatnow123's Avatar
looks like a easy install, so it corners better now?
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 01-07-2008, 02:11 PM   #6
OJOE
Crew Cut
OJOE's Avatar
looks good, but why is it mounted so far forward?
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 01-07-2008, 03:52 PM   #7
sick69
sick69's Avatar
It doesn't need to be mounted on the rear end. I does need to be parallel to the rear end and the ground and secured at both ends at the end of both arms.
I would think the closer to the rear end it's mounted the stiffer it will be due to less leverage behind it but i'm no suspension guru so that not be true.
I believe you could probably mount the anti sway bar to the frame and run the end links to the rear end. Which is what I may end up doing for clearance reasons.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 01-07-2008, 08:05 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Great mod Chris! I've always thought about adding one to my truck, and now it sounds like I need too.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-07-2008, 11:24 PM   #9
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Would a leaf spring truck also benefit from a rear sway bar?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 01-08-2008, 02:50 AM   #10
Yes,maybe more since the leafs tend to warp.
Old 01-08-2008, 03:37 AM   #11
OJOE
Crew Cut
OJOE's Avatar
Frank
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 01-08-2008, 03:42 AM   #12
Luvlegs
Luvlegs's Avatar
I couldn't believe what a difference the front one I added made. I assume you had one on the front already and this might sound stupid but how many times better did you notice it with the rear one too? (best way to word the question I guess...)
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 01-08-2008, 06:25 AM   #13
Huck
Huck's Avatar
Did the package come with installation instructions that give measurements of where to mount?
Huck is offline   Reply With Quote
Old 01-08-2008, 06:33 AM   #14
Andy4639
Old member
Andy4639's Avatar
I just finished a adjutable track arm on the 71, next up is a sway bar. I'm going yard hunting to get mine I hope. It looks just like the front sway bar I have with longer tie down ends links. Will see what's out there.
Nice install by the way!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-08-2008, 06:37 AM   #15
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
So if I am reading this correctly, all of the holes you needed were there already to mount it?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-08-2008, 06:38 AM   #16
70c10
67-72 Addict!
70c10's Avatar
There was a post a few years ago about using an 85' IROC-Z rear sway bar setup.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-08-2008, 06:42 AM   #17
70c10
67-72 Addict!
70c10's Avatar
I found this today.
http://www.classicperform.com/Instru...dco/CP954U.pdf
Looks like the key here is to form a 90 degree angle.
Jim
Old 01-08-2008, 06:59 AM   #18
ChevyDude
Hellwig makes one that you DO NOT have to drill anywhere! This is the one I put on Lil' Red. Comes un-painted so you can paint or Powder Coat to match your truck:
http://store.summitracing.com/partde...5&autoview=sku
Alex
Old 01-08-2008, 07:08 AM   #19
70c10
67-72 Addict!
70c10's Avatar
Alex- that looks beefy for the price! Most of the ones I have seen were like 7/8".
Jim
Old 01-08-2008, 07:28 AM   #20
ChevyDude
It is a nice one for sure. I think Frizzle Fry is going to get one and have it sent to me first...gonna Powder Coat it for him.
Here is mine that I ordered for Lil' Red as it showed up at my place. Even though I ordered it un-painted...it arrived with black paint??? If you want to drill install you can do that also, but don't have to.
Alex
Old 01-08-2008, 07:40 AM   #21
70c10
67-72 Addict!
70c10's Avatar
Looks like an easy install either way!
Jim
Old 01-08-2008, 01:00 PM   #22
powell72
powell72's Avatar
I'm gonna try to answer all questions:
It seems to be almost twice as good now handling wise between the rear bar install AND the poly bushings on the front. My old ones where completly shot.
There where instructions on where to mount it, I just decided to use my own judgement(???). It's so far forward because of the frame kick-up for the rearend, I didn't think the end links would reach. Also you need to consider the trailing arms angle towards the outside of the truck as they get closer the rearend, the bushings mounted on the trailing arms are only 2'' from where the bar bends forward now.
Drilling was required with this kit.
I wanted to keep the bar close to parallel with the trailing arms.
I went with this kit specifically for the fact that it was a 7/8'' bar. I feel a rear bar that is as big as a front bar, especially on a truck that has no weight in the back will cause some ill handling. Most of the bars I've found are 1-1 1/8'' and my front bar is the 1 1/16'' version.
Would I recommend a rear bar? Yes. Would I tell anyone which one to buy or how to install it? No.
Chris
Old 01-08-2008, 03:23 PM   #23
ChevyDude
Chris, Good job on the sway bar install, they really make the back end feel tight. I was in no way was I trying to say one bar was better than the other. Just an option for anyone that doesn't want to drill.
Alex
Old 01-08-2008, 05:28 PM   #24
powell72
powell72's Avatar
Thanks, and trust me Alex, I didn't take it that way at all. In fact, if I had a bigger front bar I would have went with the same one you have. I think your's is nicer!
BTW, do you have a pic you can post showing where your bar is compared to the rearend?
Chris
Old 01-08-2008, 05:36 PM   #25
c10crazy
Like a Rock!
c10crazy's Avatar
This is a good thread. I have the stock 1 1/16" bar. I have thought about getting a rear sway bar but didn't realize my handling would be WORSE with a bigger rear bar. Is this really true?. I'd hate to spend money and be disapointed.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
