01-08-2008, 05:28 AM | #1 |
Floor Shift from Van Tilt?
What does it take to make a 4spd floor shift tilt column from a column shift tilt?
01-08-2008, 06:05 AM | #2 |
Born Psycho
Re: Floor Shift from Van Tilt?
Tim,
i got the pieces necessary from an older GM car tilt with a floor shift--the cup where the shift handle was and the upper tin cover. i got lucky finding those pieces but a little JB Weld should fix the shift handle issue and the upper cover is tin so welding/brazing/soldering should be no problem. hope this helps. by the way, i didn't destroy a good column to get the pieces i used, it was already butchered up.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
01-08-2008, 09:20 AM | #3 |
I JB welded my van auto column for a floor shift. Should be about the same thing...
01-09-2008, 09:19 AM | #4 |
Post Whore
Here's a link showing my conversion for my K20. JB weld and I used some cut out pieces from a beer can to help fill in the large areas with JB on top. Sands down real nice.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
01-09-2008, 01:41 PM | #5 | |
