Old 01-08-2008, 03:50 PM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
Question Help! Low Buck Drop Spindle Install '69 w/ 6 Bolt Discs
alright, I'm ready to "start" the purchasing of all the components I will need to lower the front of my '69 1/2 ton. I have 2" drop springs already installed in the front and 5" drop springs out back. I want the front down a bit more and the only good choice I have is to go with drop spindles.
here's the question. what is the cheapest I can gather the necessary parts for this drop. I know I will need:
1. spindles
2. rotors
3. calipers/shoes
4. bearings
5. brake lines
6. proportioning valve
7. tie rod ends
8. ball joints
has anyone put together a "recipe" for a budget drop. furthermore, do you have p/n's, locations to purchase, etc.
or should I just bite the bullet and purchase a kit for $700-ouch!? help me out guys!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 01-08-2008, 05:10 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Help! Low Buck Drop Spindle Install '69 w/ 6 Bolt Discs
I bought the GMC Paul kit for $470 and it took 70GMCer and me a total of 7-8 hours to install it. I went with the drop spindles also.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-08-2008, 05:16 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
tcb-1,... I would recommend using a 73-87 donor crossmember / parts truck. The reason: All the parts are cheaper. Balljoints, tie rods, calipers, rotors, etc. Here's the problem. How much of that stuff on your list do you want "used parts" on? I did this on my blazer. In theory,... I could have used the dust shield, and the bearing cap. Everything else I wanted new parts. When you start pricing,... check the prices of 71-72 stuff. Then check prices of the 73-87 stuff. (heavy duty 1 1/4" rotor only) The later stuff is much cheaper. You have to buy drop spindles and 6-lug rotors. How much other stuff do you want to buy new? Calipers are cheap. Check out the price differences. You will most likely need a "conversion" rubber brake hose. And you will need the "conversion" tierod sleeve. You can also swap the entire steering "parts" from 73-87 trucks. (if you have to replace it anyway) Inner and outer tie rods, centerlink, pitman arm, and etc. All these parts are cheaper in the 73-87 version. On my blazer I just pieced it together and bought all parts new. Maybe that kit price isn't too bad afterall.
Keith
Convert to disc brakes.
Old 01-08-2008, 06:12 PM   #4
joehalford01
joehalford01's Avatar
i just bought a 77 parts truck for this myself. $100, it's tore up but the suspension is all good. Napa has quality parts and an awesome site, napaonline.com You can look up the parts and view them from several different angles, get the part numbers and prices and walk into your local napa with a list. Alot easier if you ask me as far as going the individual pieces route. It's funny how cheap calipers and rotors really are. I was a little suprised.
joehalford01 is offline   Reply With Quote
Old 01-08-2008, 06:36 PM   #5
slammed1
1972 Chevrolet SWB
slammed1's Avatar
There are quite a few companies offering 6 lug spindles for discs as well as rotors/caliper kits,and even drop spindles. Early Classic Enterprises,McGaughys,Performance Online and others offer kits so that stock 97-70 trucks can run front discs and 6 lug.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 01-08-2008, 07:03 PM   #6
CG
BlahBlahBlah
If you dont want to spend the money on the disk upgrade right now you can use what people call stepped a frames instead of dropped spindles. You get about the same drop. You can use the frames with drop springs but not drop spindles. So if you want to upgrade to disks at a later date you have to use a stock spindle. Not really a bad deal since you can get those cheaper (usually)
Old 01-09-2008, 08:19 AM   #7
tcb-1
tcb-1's Avatar
70c10,
$470 is resonable for me. I looked at GMC Paul's website and couldn't find this kit. Have you got a kit pn#?
Doug
Old 01-09-2008, 08:50 AM   #8
jkaylor68gmc
jkaylor68gmc's Avatar
yeah but new disc brakes are the way to go. Secondly I might not go with a '73 crossmember because you may spend more money rebuilding someone elses junk. It may be cheaper to maintain later on but the initial bite may hurt. I would recommend the normal drop spindle brake kit from No Limit engineering. I think it costs around 475.00 for spindles and brakes. No booster or master though. I just put a new brake kit on my '68 and SSBC told me you do not need a prop valve if you have a drum/drum truck already because those are just distribution blocks from the factory. I saved 100 bucks thanks to them and installed a disc/drum master and booster and an adjustable prop valve on the back. Hooked it right up to the factory prop valve.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 01-09-2008, 09:48 AM   #9
70c10
67-72 Addict!
70c10's Avatar
Originally Posted by tcb-1 View Post
70c10,
I used part number 133163. I had to buy a new 71' MC locally for $14 and picked up a 71' prop valve at the junk yard for $5. Also needed to buy a few brake line fittings to adapt the lines to the prop valve ($7) http://www.gmcpauls.com/Brakes&Steering.htm
Jim
Old 01-09-2008, 12:03 PM   #10
Retro68
I have everything you need if you would like to convert your truck over to 5 lug 5 inch bolt pattern. Here is the list. Complete idler arm, steering rod and tie rod ends. Westin 2 inch drop spindles, upper and lower ball joints, rotors, calipers, brake pads. Rear 5 bolt axles, backing plates, drums, complete brakes with pads. Also power steering, power steering pump, tilt steering column from a 1972 Chevy truck. I have inspected all these parts and remanufactured everything except the power steering pump and the steering box they didn't need it. PM if interested.
Retro68 is offline   Reply With Quote
Old 01-09-2008, 03:01 PM   #11
tcb-1
tcb-1's Avatar
Retro,
Thanks for the offer, but I'm staying 6 lug. You should post it over on the for sale board. bet you could sell your conversion quickly since you have the whole enchilada.
thanks again for looking out.
Doug
