Old 01-08-2008, 04:19 PM   #1
Jim_PA
Tilt column ID (pics)
Can anyone tell me what this came out of? Thanks!
Jim_PA is offline   Reply With Quote
Old 01-08-2008, 04:30 PM   #2
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: Tilt column ID (pics)
That Looks To Me Like A 69-72 Chevy Truck. Just Need Pics Of Lower End To Be 100% Sure.
KevsClassics is offline   Reply With Quote
Old 01-08-2008, 05:28 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
could be truck, or early van. The 72 - 75-ish vans had the horse shoe shaped turn signal plug, long shifter, and that font on the perndle.
Like Keven said, we need to see the other end to be sure what it is.
Judging by the steeringwheel, I'll guess 74/75 van.
Old 01-08-2008, 07:31 PM   #4
89 crew
For a van I believe it will fit up to 78.
89 crew is offline   Reply With Quote
Old 01-09-2008, 12:46 AM   #5
Longhorn Man
From the digging around that I have done, I am 99% sure that in 76 they went to the smaller wheel and shifter.
Old 01-09-2008, 03:45 AM   #6
Jim_PA
I'll get some more pics hopefully today! -- Thanks!
Old 01-10-2008, 06:08 PM   #7
Jim_PA
Pics added - do those help?
Thanks again
Old 01-10-2008, 06:19 PM   #8
SIXT8LOU
SIXT8LOU's Avatar
Go To Lmc,,,truck Look At Pix Of Steering Wheels,,its Looks Like 76-81 For Sure,
SIXT8LOU is offline   Reply With Quote
Old 01-10-2008, 07:22 PM   #9
Rod
Check if there is still apart number on that sticker by the neutal safety switch..looks like truck 69-72 to me though with the new pics added.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-10-2008, 07:50 PM   #10
KevsClassics
TILT COLUMN GURU
I am 100% sure that is a true truck tilt. Notice the location of nuetral safety switch, the firewall seal retaining plate,the dash seal,the short shaft sticking out the lower end also that intermediate shaft is from a 69-72 truck. Most definately not a van tilt.
Old 01-11-2008, 03:20 AM   #11
Jim_PA
Thanks! - I'll get those numbers too.
Old 01-11-2008, 03:21 AM   #12
Jim_PA
Thanks!
Old 01-11-2008, 03:48 AM   #13
Andy4639
Old member
Andy4639's Avatar
Looks like a truck that someone put a later model wheel on. Not uncommon to see.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
