Old 01-08-2008, 04:25 PM   #1
skydiver
Just a fan.
skydiver's Avatar
Question Posi Differential for 1972 C10
Hello All,
I am looking for some advice on rear differentials for my 1972 Chevy C10. I am looking to swap out my standard 12 bolt non-posi differential for a posi. Does anyone have experience with this? What should I look for in buying a posi differential? What type of information do I need to make sure it will fit my truck? I have seen that there are different numbers of splines, how do I tell which number I need? Also, is this something that can be done in my garage or do I need special tools, etc. Any advice will be helpful.
Skydiver
1972 Chevy C10 LWB
350 4 bbl
skydiver is offline   Reply With Quote
Old 01-08-2008, 08:19 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Posi Differential for 1972 C10
I just went with an Eaton posi and 3.73 gears in my 12 bolt. The Eaton is both rebuildable and adjustable. Had someone else do it all for me though though.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-08-2008, 08:26 PM   #3
68350
68350's Avatar
depending on the gears, that will determine which series carrier you need(I believe only the series 3 and 4 are used for stock geared trucks). I would go with an eaton posi, seem to be about the best all around posi set-up. New gears wouldn't hurt, either. While you're at it, if there are any worn seals or gaskets or anything that's not in very good condition, you might as well replace it. I am not sure if you need any specialty tools, but I'm gonna say no, it is something anyone should be able to do in their garage. U might try to find a book or video to help with the process if you're doing it buy yourself. hope this helps
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 01-09-2008, 02:26 AM   #4
70GMCer
70GMCer's Avatar
There are two areas I do not tackle, rear end setups & front end alignments. It is advisable to have a shop do it. The wear pattern needs set correctly with shims. Also you might need other parts like a new pinion bearing, etc. You want this done right the first time. Posi units are not a cheap thing just too throw in and go.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-09-2008, 05:48 AM   #5
Psycho71
Psycho71's Avatar
Like others have said, the Eaton is a good unit. Or they get their share of compliments anyway.
For 3:73's or numerically higher gears, you'll need a 4 series carrier.
For 3:42's and lower, you'll need a 3 series.
You'll need a unit for a 12bolt Truck rear end. It will have 30 splines, if I'm not mistaken. They are not the same as the carriers for cars. Well, I think a few of them cross over, but you'll want to specify "truck" just to make sure.
You can get the higher ratio gears to work on the 3 carrier, but they are different and cost a little more.
As far as setting them up goes, you might want to have a shop do it. You'll need a pinion depth gauge, and a dial indicator on a magnetic base.
You can do it yourself, I did my own. But mine was just a carrier swap, so the pinion never moved, meaning I didn't need the depth gauge. I downloaded instructions from Richmond's site, and followed them to the "T", and everything works great (and has for two years now). So it's not impossible. There are a few tricks I've learned since then, and will employ on the next swap. Getting my wear pattern right was actually pretty easy to do. But again, I never had to move my pinion from the stock location. I'm sure it gets much more complex if that's necessary.
There are also lockers available. This would be a good idea if your not changing the gear ratio. As they just replace the spider gears in your stock carrier. They usually cost less too. Some people complain about a ratcheting/popping sound they make when cornering, but Richmond makes one now they "Claim" doesn't do that. It's called the Powertrax Unit. They say it installs in about an hour with no special tools. But again, it's only a viable option if you just don't want to upset the gears. If changing gears too, I'd go with a complete carrier replacement unit myself. Like the Eaton.
I'm probably going to try one of the lockers later this year, just because I don't want to have to set-up my gears again. I should have put a new unit in when I did them two years ago, but the money just was there at the time.
Good luck,
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 01-09-2008, 08:19 AM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
It's not that hard to set up a ring and pinion. There is plenty of info online. Just take your time, and check your measurements. It's not a black art
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-09-2008, 10:27 AM   #7
nightmare
nightmare's Avatar
Don't mean to step on anyone's toes, but Jay, when you did just the carrier swap, did you have to shim the carrier any? I basically did the same thing, and my pinion didn't move, but I didn't do anything else but pull the carrier, move the ring to the other carrier, and reinstall it back in the rear. I haven't put the axle into use yet, but will be soon, and don't want to have to pull it back out because I messed something up. I checked for a wear pattern, by doing chalk on one of the teeth, and it showed to be in the middle. Should this be fine? Thanks for the input.
Mike
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is online now   Reply With Quote
Old 01-09-2008, 11:52 AM   #8
Wasted Income
Boosted Member
Mike
Turbo diesel
Old 01-11-2008, 08:51 AM   #9
Psycho71
Psycho71's Avatar
Mike
Yes, I did have to play around with the shims to get the wear pattern correct, but it was pretty easy to do. I did actuallly replace all the bearings as well. I just re-used the pinion shims so it went back in the same location it had been, then it was just a matter of geting the carrier shimmed to where the wear pattern was good. The hardest part was adding the extra shims to get the preload on the bearings. .010" doesn't sound like much until you try stuffing the carrier in a whole where it don't want to fit.
I did have my rear end out of the truck, so I know that alone made mine easier.
Jay
