1972 front wheel bearing #'s?
I just purchased a set of ECE drop spindles, and it reccommends that I do the front wheel bearings at the same time to avoid damaging the new spindles. What all is involved in this, and what all do I need? I assume 4 bearings, 4 races and 2 seals, but I'm not sure what #'s I need or if all this is necessary? I can get Timken and NTN bearings through work, and CR seals as well, but don't know the numbers. Any help would be great. Thanks!
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
Re: 1972 front wheel bearing #'s?
The inner bearing set is BR5 that is bearing and race
The outer bearing set is BR3 Seal is 19984 that is a CR seal the bearings are Timkin. Hope this helps |
Should help a lot. Thanks!
Just to make sure, I need two of everything you listed to do both sides, correct?
![]() Join Date: Sep 2005
yup 2 inner and 2 outter and 2 seals.be sure to full the bearing with greece,
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 01-10-2008 at 02:47 PM. |
