01-08-2008, 07:15 PM | #1 |
Blue 67
Need tranny education
Hello:
Would you give me some information about these kinds of manual transmissions: rebuilt 4 speed saginaw, a rebuilt Muncie 4 speed transmission, and a Borg-Warner T-5 with overdrive . Which one would you chose if you had option to pick one? Thanks
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner Last edited by Nima; 01-08-2008 at 07:22 PM. |
01-08-2008, 08:03 PM | #2 |
Re: Need tranny education
Depends on what you're putting it in and its intended use. I would not bolt a saginaw to anything over 300 fwhp.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
01-08-2008, 08:15 PM | #3 |
probably the muncie, depending on which one it is. if the borg warner was a super T-10, then I would take that one.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
01-08-2008, 09:06 PM | #4 |
ifyour not goingto abuse it the t5 would be fine, if your gona pound it go with the t10 or the munci
common sense isn't so common anymore |
01-09-2008, 11:53 AM | #5 |
Fabricate till you "puke"
Look at the prices on the rebuilds......from what i have seen, the Muncie commands a big price. its a good trans, but you can purchase a NEW T -10 fo just a little more, & have more options on ratios(check Summit or Jegs). now that saginaw trans is not a bad pc...IF you dont race it, or play "speedracer" from lite to lite. The biggest prob I see , is ratios.....a 4000 lb truck dont get with a 2.20 1st gear that the close ratio Muncie has, unless its running 4.10 or lower gears. You can get a 2.88 1st gear in a Borg Warner(Richmond) T- 10. The spacing is a little far, but it will walk you out of the hole quick with w 3.42-3.73 gear.....forget the T5, its absolute JUNK, unless all you do is cruise easy. Best of fun, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
