Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-09-2008, 12:27 PM   #1
68gmsee
Active Member
68gmsee's Avatar
Bonus money suggestions needed...
I retired in October of last year and was surprised with a small $700.00 bonus. I'm starting to restore my old trucks and here's what I need.
Air compressor (size?)----could be used for sandblasting/painting.
pressure sprayer------could be used for cleaning/wet sand blasting.
mig/tig welder--------rockers, bottom doors, front fender patch panels.
And here's the problem. I can only buy one now and it may be 6 months before I can save for something else.
I have 20 acres in the country where I keep my trucks and have electricity but no water. Only a lean-to to keep my trucks in.
Which one would you buy first?
68gmsee is offline   Reply With Quote
Old 01-09-2008, 12:28 PM   #2
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Re: Bonus money suggestions needed...
Lowes,Home depot and others have 60 gallon 6.5 hp air compressors for right at 390-420 at times and 110 welders with gas arent that expensive if you check around.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 01-09-2008, 12:42 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Thanks slammed. That's one for the compressor first.
Any more suggestions?
Old 01-09-2008, 12:55 PM   #4
cdowns
cdowns's Avatar
i'd say welder the bigger the better// cuttin and fitting can all be done easily with readily available hand tools such as jigsaws hacksaws sawzall grinding using a drill motor etc// in my experience its best to do the welding and metalwork before worrying about paint and body type stuff
Old 01-09-2008, 01:06 PM   #5
72 cheyenne pdx
72 cheyenne pdx's Avatar
w/Cdowns I think the body work is more important that the other 2, but it also depends on what you consider the best return would be. I don't know what other hobbies you have, but if you are into woodworking then the aircompressor could be a better investment since there are air tools for woodworking. If you are into metalworking, then you may want to go towards the welder. If you like to pressure washing everything insight, then that is what you should get.
Good luck with your decision and have fun.
72 cheyenne pdx is offline   Reply With Quote
Old 01-09-2008, 01:16 PM   #6
BB70c10
BB70c10
BB70c10's Avatar
i'd say compressor,hands down.i dont have either one yet.i could have used the compressor every time i've touched the truck.my truck is down to pretty much a rolling chassis.the only thing left on it is the suspension,tires,rear end,and the bed(which is in 3 pieces) and ive only needed the welder one time to tack two poles on the top of the bedsides.if i had the money right now,i'd be buying a compressor TODAY.if youre like me,you wont be welding,cleaning,or sandblasting every day,but i almost guarantee you'll use the compressor pretty much every day if you had it.you'll pretty much have to use the compressor to get to the point where you would need the other two,and you'll still need it when you're done with them.i've gotten along way without either of those,but if i did have a welder and sandblaster,id trade them today for a compressor without a doubt.jmo
BB70c10 is offline   Reply With Quote
Old 01-09-2008, 01:35 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
The only thing I can tell you is that I use my compressor a heck of a lot more than I do my welder or pressure washer....
LockDoc
Leon
Old 01-09-2008, 01:38 PM   #8
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
When buying your compressor, someone mentioned Home Depot and Lowes, don't forget about Sears. Watch the Sunday Newspaper or visit there they often include a combo air tool set when you buy certain compressors (impact gun, air ratchet, die grinder and/or fittings and connectors).
Good Luck
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 01-09-2008, 02:00 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Thanks for input. So far the compressor is ahead.
Any more suggustions?
Old 01-09-2008, 02:30 PM   #10
ksjh1316
ksjh1316's Avatar
Along the sears line don't be afraid to go to their service work store they have all the items there that have scratches in them at 40% off of what the store has them at. They also have last years models they could not move at the store cheap. Say all those items in mine last week.
ksjh1316 is offline   Reply With Quote
Old 01-09-2008, 03:03 PM   #11
LockDoc
Ditto.
Compressor is most used
then welder,
then pressure washer
I got my compressor used. A friend had just gotten a bigger and better system, so he traded me the compressor for doing some computer work for him. Sometimes bartering is a good thing!
Palf70Step is online now   Reply With Quote
Old 01-09-2008, 03:33 PM   #12
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
As much as I'd love a welder, right now almost everything that needs done on both the Blazer and the pickup I'd need a compressor for. Plus my son's bicycle seems to ALWAYS have a flat tire, and there's lots of other jobs that air tools would make easier.
As far as a pressure washer goes, as little as I need one, it's cheaper and more convenient to rent it for me. Someone else has to do the maintenance (mine would sit so long the carb would gum up like my snow blower did this year), and if it breaks (like my last one did) they have to fix it as well.
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 01-09-2008, 06:07 PM   #13
Woobie
Woobie's Avatar
Hands down, the air compressor! Built a new house 2 1/2 yrs ago with a 24'x24' shop in back. One of the first things I did was hard plumb air outlets across back wall and up left side,(and under work bench front edge), with a hose reel in the middle of the ceiling. About the best thing I've done to the shop yet, besides build it. Next buy will be a welder.
Regards,
Paul
1972 c10
2000 FLHTC 126+k miles, so far
1967 BMW r60
2007 Xterra (Wife's ride)
R.I.P. "ESLL"
Woobie is offline   Reply With Quote
Old 01-10-2008, 04:20 AM   #14
68gmsee
Active Member
68gmsee's Avatar
Okay, I've been moved...
But I think I got my answer. I will go with the compressor first, then the mig welder this spring when I save a few more bucks.
Our Sears store does not carry large compressors so I have to use either Lowes, Home Depot or Tractor Supply. They all carry some pretty hefty models and fairly decent prices.
Now, if anyone has any input, is there a noise factor involved with the larger compressors? The small 20 gallon one I have sounds like a small chainsaw...
Thanks. Again.
Old 01-10-2008, 08:52 AM   #15
myoldchevytruck
Well, the bigger compressors do make more noise - especially if it has a belt BUT now your putting yourself in a whole new ball game. Now your CFM's are higher and your die grinder...grinds longer. Also, you are able to use other air tools which require the higher CFM such as as nibbler or cutting shears. Small capacity compressors are great, especially for portability and most of the jobs you'll encounter but do have there limitations. Determine your needs for your compressor such as you did for the welder and the pressure cleaner.
Good Luck.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 01-10-2008, 09:30 AM   #16
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
do what al bundy would do ---
go to the nudie bar
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 01-10-2008, 10:04 AM   #17
bobthecop
bobthecop's Avatar
I use my compressor way more than the welder, probably I don't know how to weld very well, and I have not practiced. I had an old 25 gal sears oilless and taht thing was so loud and ran out of air every 15 sec or so, I had already collected 21 different air tools, and with the new IR 5 hp compressor I don't run out of air at all, and I use it alot. Guess I start getting practiced with the welder, a lincoln 135 wire feed mig.
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 01-10-2008, 10:46 AM   #18
jkaylor68gmc
jkaylor68gmc's Avatar
Welder, You can remove everything by hand or with a sawzall, the welder would allow you to repair the parts that you have removed. Odds are you will be in the welding repair atage for a while.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 01-10-2008, 12:28 PM   #19
68gmsee
Active Member
68gmsee's Avatar
go to the nudie bar
I think I'm getting too old for that, but thanks for advice.
Old 01-10-2008, 12:46 PM   #20
dwaite72lnghrn
Look at your projects and see what they need. If they need alot of panels then get a good mig with gas setup. If you need wrenching and sanding and cutting get a compressor.
When you go for a compressor check all of the tools you will need and make sure the compressor you buy will keep up with them. A jitter bug sander will need about 6-9cfm, A impact wrench will need about 6-12 depending on brand. Look at Ingersol Rand tools they have some of the lowest cfm needs compared to harbor freight and others. A bigger tank is better, my small cambell hausefeild compressor is rated at 7.8 at 90psi and will run the 5hp motor all day to keep up with a sander. That is expensive sander to run all day. So I use cheap electrics sometimes they just burn out quicker. The air tools will take the abuse as long as you keep filtered air running in them and oil them if needed every time you use them and before you put them away.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 01-10-2008, 02:40 PM   #21
Truckstr
Truckstr's Avatar
dwaite said what I was going to say. You'd be smart to take a good hard look at what you need to do to your truck(s). Make a list of goals and the tools you'll need to do the various jobs. An air compressor was my first "big" equipment purchase and I used it all the time (and still use it and a newer, bigger one). But I had to buy a few other tools to go with it - air chisel, impact wrench, paint gun, air drill, sand blaster etc. If you buy an air compressor, make sure it's big enough to run all the air tools you'll end up buying.
Then I bought a welder. I use the air compressor a lot, but when I need the welder there's no substitute. A Sawzall is hard to do without. I bought a 7" sander/grinder too. The air comes in really handy. The welder is just as useful, but is for a completely different set of jobs. It all comes down to what you need to do. You'll have to figure that one out. There is no single "correct" approach. Some are just better than others.
Jeff
'67 short Fleet; my ongoing project.
'66 long Fleet; my original "baby."
Live life or bust trying.
Truckstr is offline   Reply With Quote
