dual shocks....
My Blazer has dual shocks up front. I'm guessing that this was an add on by someone for a snow blade .......or has anyone ever heard of this being a factory option for a 1972 Blazer?
huh ???
Re: dual shocks....
Never heard of that on a 72, I know some mid to late 80's models came with duals...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Post Whore
![]() Join Date: Feb 2000
Re: dual shocks....
I also haven't seen that before on any 67-72 truck or K5. If you need to replace them, be sure to get shocks that are designed to be used in pairs.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
New Member
Re: dual shocks....
I have the same thing on a 72 Blazer that I parted out. I believe they are just aftermarket brackets, I had the identical ones on a 78 Chevy truck I had also. If you remove the paint from them they should be a goldish zinc color.
Purple People Eater
Re: dual shocks....
My '71 has dual shocks up front, but it looks completely different from yours (i'm pretty sure mine isn't stock either).
1971 K5 Blazer 396ci/TH400/NP205/Dana 44/GM 12 Bolt/38" TSLs 2004 Chevy 1500 4X2 X-Cab 327ci |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: dual shocks....
Pretty sure they are after market.
Here's a pic of the one that came on my Blazer. ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
#7 | |
huh ???
Re: dual shocks....
Yes yours is aftermarket. I installed a setup from Trailmaster on a friend's 84 Blazer that looked exactly like your setup... Chuck
