01-09-2008, 03:37 PM | #1 |
TuTone Silverado
4.1 to V8 swap???
How much work is it to swap out a 4.1 6 cyl. for a 350 V8? Mine is a 79 GMC 2wd turbo 350 auto trans truck with A/C. The V8 is the same year from a GMC Jimmy 2wd with auto and A/C.
Any trans or linkage issues? Other problems with this?
13 Corvette GS vert 13 Ram Laramie Longhorn 11 Wrangler Sahara unlimited 08 300 76 El Camino 67 Bel Air sedan 63 Corvette SWC 08 HD Road King Classic 68 HD Golf car |
01-09-2008, 04:05 PM | #2 |
Re: 4.1 to V8 swap???
change the mounts on the frame and drop her in, the V8 will bolt to the trans and no linkage problems, mite need some different brackets for a/c compressor depending which style compressor was on the V8
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
01-09-2008, 04:20 PM | #3 |
you will probly need diferent engine stands and engine mounts just get some out of a truck with a 350 and your good to go
01-09-2008, 06:19 PM | #4 |
sounds good stepin, I too have a 4.1 in my 73 and want to someday change to a v-8, maybe a 327, just waiting till the old wears out, I can't see changing a perfectly good engine till then. Please keep us informed of the process if and when you do it. thanks bob
01-09-2008, 06:51 PM | #5 |
wiring harness cut shorter. motor mounts moved one position(middle holes).
1978 c10 stepside 4/6 drop 350 vortec crate 2011 camaro ss2 6.2 automatic 2017 tahoe lt 2002 silverado lt 1500 5.3 automatic. 1981 el camino |
01-09-2008, 08:34 PM | #6 |
Wasn't there a light duty 350 made to hook to the v6's? Just like in the 700r4's? If I'm remembering right then the transmission may not hold up to the extra ponies too long. depends on condition, how you drive, and if my memory is toast!
01-10-2008, 06:39 AM | #7 |
www.73-87chevytrucks.com
Get the clamshells with the V8 and move the engine stand mounts to the "8" position, it will bolt right up. Tranny should be fine for a stock v8...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
