Old 01-09-2008, 04:32 PM   #1
syncrov69
syncrov69's Avatar
Floor repair panel!
I have to change floor panel at rear between cab corner panel and seat belt hole on both side. Where it's possible to found this part(classic parts, lmc, etc...) and what is the part number. I join picture to complete my question. Thank's
'71 Custom/10 Deluxe LWB
'71 Custom/30 Deluxe Dually
syncrov69 is offline   Reply With Quote
Old 01-09-2008, 04:53 PM   #2
Sweet72
Sweet72's Avatar
Re: Floor repair panel!
The vendors have the outer-rear floor section available, but it's only about 7"??? wide and runs from the front seat mount bolt area to the back of the cab. Most of the vendors on the board have them (GMC Paul's). Stay away from LMC. The repair panel stampings I bought from them were very poor. I had to pay shipping to send it back to them and get rid of their crap.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-09-2008, 05:41 PM   #3
DavesRide
DavesRide's Avatar
Hang in bro. Mine is worse. We will find best place for quality soon.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 01-10-2008, 03:30 AM   #4
lks dcvn
lks dcvn's Avatar
Best bet (if you need this done sooner than later) is to find a donor cab and cut these pieces out and then weld them into your cab...
no repop parts yet for that spot (or you could just replace the entire floor - they remade those, but that may be a lot more work depending on your situation).
Good Luck.
lks dcvn is offline   Reply With Quote
Old 01-10-2008, 04:24 PM   #5
Sweet72
Sweet72's Avatar
Here's a pic of the drivers side...
Old 01-11-2008, 04:50 AM   #6
Putter
More Cowbell....
Putter's Avatar
Hey Syncrov69....where is Laval Qc??
Please don't be offended, but I couldn't help but picture Borat's voice while reading your post.
"eeeh-High Five"
I agree with the "Find a donor truck" idea so you can get a section large enough. Plus you won't have a patchwork of welded seams.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 01-11-2008, 04:45 PM   #7
syncrov69
syncrov69's Avatar
Wink Re: Floor repair panel!
ha!ha!ha! Laval is in Québec Province in Canada. Normally I speak French but I make my possible to write to you in english! Sorry for my bad english!!! I think that your not better if you try to write in French. It's not easy for me to practice when every people around speak french and this forum is a good practice for me.
Old 01-11-2008, 05:04 PM   #8
GMC3
I needed these on both sides of my cab. I found it easiest to make templates out of thin cardboard and make my own out of some sheetmetal. Turned out good and I'm not that experienced.
GMC3 is offline   Reply With Quote
Old 01-11-2008, 05:06 PM   #9
GMC3
oh yeah, and redrilled for the seat belts and used a heavy, fat washer
Old 01-12-2008, 09:39 AM   #10
syncrov69
syncrov69's Avatar
Thank's GMC3 I keep your idea and use 18ga sheet metal to make one. Do you thread size for seat belt bolt near you?
Old 01-13-2008, 11:04 AM   #11
syncrov69
syncrov69's Avatar
If LMc sheet metal are not the best where it's possible to order good sheet metal.
Old 01-13-2008, 01:17 PM   #12
dingo_dan_22
dingo_dan_22's Avatar
Try an auto body supply shop. Almost all the shops here in Saskatchewan are supplied by Cross Canada. http:/www.crosscanadaparts.com
There's a warehouse in Windsor and Toronto Ontario. Most shops here don't charge for shipping and it only took a few days to get all my suff.
71' Chevrolet -> 350c.i. w/ 600 Edelbrock Carb, Headers, P/S, 3/5 Drop
dingo_dan_22 is offline   Reply With Quote
Old 01-13-2008, 02:56 PM   #13
Bob D
Rolled on Paint Club
Bob D's Avatar
I had the same dilemma. I used the above pictured patch panel and a scrap off of another.
Bob
1970 GMC 1500 swb fleetside
SB 355ci.
Smog heads
Summit 1102 cam
Performer intake and carb.
Finally in about 1 piece in the yard.
Bob D is offline   Reply With Quote
Old 01-14-2008, 01:57 AM   #14
syncrov69
syncrov69's Avatar
THis pictures from BobD help me, anybody have pictures of floor restauration?
Old 01-14-2008, 02:09 PM   #15
DavesRide
DavesRide's Avatar
I wish I did. I only have the before pics as of now. I am following this thread for sure.
