01-09-2008, 04:40 PM | #1 |
Dash Pad & Door Panel Paint
Whats Better To Use For Re-painting A Dash Pad And Door Panels???? Sen Or Duplicolor????????????
01-09-2008, 04:44 PM | #2 |
Low & Fast!
Re: Dash Pad & Door Panel Paint
SEM Color coat would be the better one..
01-09-2008, 04:55 PM | #3 |
Slugish
had good luck with duplicolor, but not on dash pads or door panels.
01-09-2008, 04:57 PM | #4 |
Slugish
Imean I havent tried any type of paint on dahes or door panels.
01-09-2008, 05:26 PM | #5 |
yeller
SEM fan here, have had excellent results.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
01-09-2008, 06:34 PM | #6 |
SEM for sure.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
01-10-2008, 09:27 AM | #7 |
What is SEM and who sells it?
Also when you paint door panels does it die it or just paint the surface? Wont the paint wear off in no time? |
01-10-2008, 09:56 AM | #8 |
Chris
online stores, restoration places sell it and auto body supply stores.
I had bad luck with sem on hard type plastic surfaces, also had some with duplicolor, but I had great experiences with duplicolor on dashes, I did the one in my monte carlo with it, no issues, arm rests and vinyl door panels, even seats with it. The sem I used to do a black 84 dash cap to blue and it seemed to take forever to notice any color on it and the can didn't go far. The duplicolor went a long way and was alot cheaper too. I would HIGHLY reccomend the use of adhesive promoter on hard plastic surfaces, like door panels in these years of trucks.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
01-10-2008, 10:01 AM | #9 |
yeller
I have followed SEM's steps by the book, no dissapointments here. Use a good cleaner, adhesion promoter, and you should be good. It all about the prep work. Here are a few pics of the console I just restored using all SEM products.
01-10-2008, 11:10 AM | #10 |
01-10-2008, 05:09 PM | #11 |
Robert Olson Transport
i bought the duplicolor and i used it on a set of door panels on my old 86 and the arm rests the paint came off almost immediately
what is the SEM stuff and where do you get it? i have a red set i wanna make grey
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! Last edited by old Rusty C10; 01-10-2008 at 05:10 PM. |
01-10-2008, 06:43 PM | #12 | |
Garage Queen Material
01-10-2008, 06:59 PM | #13 |
Chris
LOL yep that's pretty much the color blue I had to try and dye my black cap to be, turned out dark, but wasn't the exact blue anyways.
01-11-2008, 07:01 AM | #14 | |
Ive got a new set of chevyduty aftermarket red door panels that I would like to do but they are hard plastic. Seems hard to believe this stuff could penetrate? |
01-11-2008, 07:30 AM | #15 |
They make a pre-sealant for the dyes and sprays. It increases adhesion. I used SEM on my new dash for the 77. Turned out well. However, the manufacturer said NOTHING would adhere to that poly-something material. I washed, scrubed, sealed, and dyed the dash. It has held up well except in the creases around the dash bezel.
01-11-2008, 08:18 AM | #16 | |
yeller
The dye itself does not penetrate thru the panel...it is just adhered really well via the adhesion promotor, and I believe IT (the adhesion promoter) penetrates slightly into the panel. Bottom line, nothing will look new forever, but it can last longer when a quality product is used and it is properly applied.
01-11-2008, 08:30 AM | #17 | |
Low & Fast!
You said it. Did my gauge cluster and wheel. Came out very good..
The number one thing is to clean it very good.. Quote:
