Old 01-09-2008, 05:48 PM   #1
67C10SWB
Powder coating Question
Has anyone every heard of someone powder coating a vehicle? if so any pictures or information. Someone was telling me this can be done. I have powder coated many smaller parts and in my opinion is the only way to go. A couple of pics of my 67 c10 swb frame fresh from the powder coating. Before I begin to put her back together again...
Name:  mikes truck 107.jpg
Name:  mikes truck 108 test.jpg
Name:  mikes truck 109 test.jpg
Name:  mikes truck 118 test.jpg
67C10SWB is offline   Reply With Quote
Old 01-09-2008, 06:04 PM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Powder coating Question
Ive never heard of it being done, but have thought of it myself
If you had a big enough oven, I don't see why you couldn't
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 01-09-2008, 06:13 PM   #3
ChevyDude
If you are talking about the body of a car or truck, forget it. Powder coat requiers that the metal be blasted and bare. If you want the body straight you need filler (bondo). Fillers do not like heat. Most powders need to cure at 400 degrees for 10 min...filler is not going to like that... much!
Now , any bare metal can be powder coated and cooked in the oven...but it will only look as good and straight as the metal that was coated.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 01-10-2008, 02:29 AM   #4
mrein3
mrein3's Avatar
And if you ever need touch-up you're screwed. You'd have to re-coat the whole piece.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-10-2008, 05:21 AM   #5
Number98
Prestige Worldwide
Number98's Avatar
There was an article in Hot Rod a while back where they built a 70's Camaro and they had the body stripped and then had it powder coated instead of a painted on sealer. I believe there theory was that the powder can reach behind panels and inside areas that paint could not reach. I do not remember which issue, I just recall the article. I do remember them mentioning how the heat that's required to melt the powder can cause the panels to warp and also some of the factory lead filler melted and ran out of some places. After the powder coating they performed the body work and painted it as normal, they just used the powder coating as a sealer/primer.
Number98 is offline   Reply With Quote
Old 01-10-2008, 06:23 AM   #6
c10addict
c10addict's Avatar
It has been done... The camaro is called the F-Bomb.. Here is a pic and a link to the story... This car is SICK!! One of my best evers!!
http://www.nelsonracingengines.com/i...2007_fbomb.pdf
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 01-10-2008, 07:01 AM   #7
mburgert
mburgert's Avatar
I went on a field trip to the Kinze farm equipment plant in IOWA and the owner built his daughter a jeepish looking car and powder coated it. He has the ability and the ovens to do it in since they powder coat their huge grain wagons. It looked pretty good.
mburgert is offline   Reply With Quote
