Decision time
I scored an LT1 out of a 96 Camaro from a guy I work with and now I'm trying to decide if I should put it my 67 or in a 90 S-15 I can pick up for super cheap. It would be nice to have something to pull a trailer with, the 67 would do that, but the S-15 would scoot with the LT1. What do you guys think?
1947 1/2 ton, 5.3, 4L60E, 10 bolt 1974 Jimmy, 4 inch lift, 35" Thornbirds sold ![]() |
Re: Decision time
I vote for the '67, just my .02 worth.
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) ![]() 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again ![]() 2002 Tarus (my wife loves that car) |
Re: Decision time
The S15 could pull a small trailer, but since this is a 67-72 forum -- i'll vote for the '67 too
Are you retired too? Nonsense! I'm in my prime |
Fabricate till you "puke"
Re: Decision time
I built 3 of those "pocket trucks", 2 s -10's, & 1 ranger......they ALL had sb Chevs(including the little Ferd). They all were fun to play with, but got me into a little trouble(woops!) Also, everything fit D@MN tight in a v-8 little truck......not so much fun to work on! You need to weigh fun in 1 hand, & tow /work horse in the other......decide what you want/need the baddest
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Re: Decision time
I hear you guys, I built a V8 S10 before and it did get me one speeding ticket, that was when my wife told me to sell it. I'll most likely do the 67 as I would like to have something to pull a car trailer and I have my 47 if I want to lay down some rubber.
Re: Decision time
...if you already have a hot-rod, put it in the 67.
BUT there is no reason that the 67 cant lay rubber, AND pull the trailer at the same time ![]()
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
