Old 01-10-2008, 12:38 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
need help with spindle removal
im changing out the ball joints on my truck and i have removed the rotor and caliper at this point. i also have the spring compressed. i have removed the nuts on both ball joints and i cant get the spindle loose from them. i have also tried to pry the upper control arm loose. what else can i do at this point? im also a little nervous about the dangers involved with the spring.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 01-10-2008, 12:54 PM   #2
bob1967
bob1967's Avatar
Re: need help with spindle removal
the easiest way is go to the parts store and get a ball joint removal tool. you are also going to need a ball joint press to get the ball joint in if they are pressed in
bob1967 is offline   Reply With Quote
Old 01-10-2008, 12:55 PM   #3
cdowns
cdowns's Avatar
the spring myth of it decapitaing and maiming for life is a good one
do you have a pickle fork or ball joint seperation tool? with the nuts on the ball joints whackin the crap out of the pickle fork releases the balljoint from the spindle then using a jack under the lca and nut off lower balljoint lower to get spring out
Old 01-10-2008, 01:05 PM   #4
El Jay
Gone to greener pastures
PUT THE NUTS PARTIALLY BACK ON.
It's just a minor safety precaution to keep everything from flying apart.
Coil springs store an enormous amount of energy and are very dangerous.
This stuff can't be stressed enough.
Right, or wrong, here's how I have done it in the past.
I'm assuming you have the shock absorber disconnected, or removed.
First of all, I jack up a floor jack against the lower control arm, not enough to compress the spring, but tight enough to keep the control arm from dropping, & the spring from flying out (a very bad thing!)
If you don't have a pickle fork, smack the spindle in the area of the ball joint w/ a 4# hammer.
It's a taper fit, so sometimes it's hard to get the ball joint to separate from the control arm.
This works for both the top & the bottom
As a friend of my son once said, "I've never seen anybody use a 4# hammer like you guys."
El Jay is offline   Reply With Quote
Old 01-10-2008, 01:06 PM   #5
john
member #16
john's Avatar
Always leave the nuts on loose until the spring pressure is off. The pressure is what helps break them loose. Do as cdowns said and use a pickle fork or ball joint tool. Once broken loose put jack under arm and remove nut and lower. The only time I have ever needed a compressor is with no engine weight.
john is offline   Reply With Quote
Old 01-10-2008, 01:22 PM   #6
faribran
EL Jay's plan works.... thatz the way i did it..
faribran is offline   Reply With Quote
Old 01-10-2008, 01:26 PM   #7
crm318
crm318's Avatar
after i posted, i remembered that i need the ball joint tool. the spring compressor is still in so ill leave it. thanks for the info guys.
1972 Cheyenne
Old 01-10-2008, 05:25 PM   #8
El Jay
I'm baaaaaaaaaaack.
As an aside, it's not a bad idea to run a chain thru the coil spring to keep it from decompressing 100% when the ball joint breaks loose.
I hate to keep harping on it, but springs worry me sometimes.
I won't say how I know this, but, back in my misspent youth, "somebody" had a spring come loose & bounce off the exterior wall of the living room.
Fortunately, nobody was in the flight path of the spring.
My bride, in our new house, was somewhat less than happy.
Wimmens!
