Old 01-10-2008, 04:29 PM   #1
Travis K
Travis K's Avatar
What could be causing this
I am having two problems with my truck:
1.) When I start the truck, the starter turns really slow and sounds like it is being bogged down. The battery and starter are both new. It is not grinding at all, and the truck eventually starts, it just does not sound healthy. Could the starter be too close to the flywheel and be pressing on it or something?
2.) After the truck is started, it stalls when I shift it into gear and a load gets put on the motor. The tranny is a new rebuilt TH350, and the converter is brand new.
Any help here would be great.
Travis K is offline   Reply With Quote
Old 01-10-2008, 04:32 PM   #2
chev74
Addicted to Chevy
chev74's Avatar
Re: What could be causing this
for problem #1: are you sure that you have quality connections for the positive and for the ground? Is this a NEW starter or a remanufactured one?
chev74 is offline   Reply With Quote
Old 01-10-2008, 04:36 PM   #3
Travis K
Travis K's Avatar
Connections are good, I replaced the battery cables recently. Not sure if the starter is new or reman. Everything was cranking well before I did my tranny swap.
Old 01-10-2008, 04:38 PM   #4
haysonj
haysonj's Avatar
I would check the timing it sounds like it may be retarded too much or your torque converter is binding. Try disconnecting the converter from the flex plate and see if it turns over faster.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 01-10-2008, 04:40 PM   #5
Eichorst69
Timing may cause both problems.
Rob
Eichorst69 is offline   Reply With Quote
Old 01-10-2008, 04:41 PM   #6
webbes
If it started after you done the tranny then that is where I would start. Main for problem number two but I would do haysonj said and disconnect the tc to start with
1970 4X4 LONG BED 350 TPI 700R4
webbes is offline   Reply With Quote
Old 01-10-2008, 04:44 PM   #7
Eichorst69
Could the distributor have been bumped when swaping the tranny?
Rob
Old 01-10-2008, 04:54 PM   #8
89 crew
If you didn't block the back of the engine up when you dropped the tranny the distributer will hit the fire wall. if so that could tweak your timing. Heck if done hard enough it could bend the distributer. Did you change the flywheel, or starter while the tranny was out? If not then it shouldn't be able to change the gap between teeth. I would still double check the ground connection. to make sure it is good you can use jumper cables from the neg post to the block. If none of that helps it is time to go deeper.
89 crew is offline   Reply With Quote
Old 01-10-2008, 04:56 PM   #9
Sweet72
Sweet72's Avatar
The "new" starter snout may not be the correct one, causing a misalignment between the starter gear and the ring gear. manually engage the starter gear and check for interference or binding. I have heard you can also use a paper clip as a feeler gauge. Is the flexplate new? Is it the right diameter? There are two sizes of flexplates, a 53 tooth and 68 tooth I believe. The starter may just need shimming. The previous posters are assuming that the starter problem and engine dieing under load are related.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-10-2008, 05:09 PM   #10
clay68c10
clay68c10's Avatar
If your torque converter isn't splined up all the way on the trans front pump you'll get a pretty bad drag. An easy way to check that is if you can unbolt the converter from the flexplate and push it back far enough to spin it.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-10-2008, 05:27 PM   #11
BarryB
BarryB's Avatar
Sounds like this guys already have you heading in the right direction. but I would check the clearance on the starterdrive and a fly wheel, It might be in a bind. Therefore, putting the starter in a bind.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 01-10-2008, 08:28 PM   #12
tsetsaf
I vote the tranny/ torque converter issue. Only item that makes sense other than the distributor getting smacked.
tsetsaf is offline   Reply With Quote
Old 01-10-2008, 08:38 PM   #13
Travis K
Travis K's Avatar
Thanks guys. I am going to test all of these ideas out tomorrow night.
Old 01-11-2008, 01:40 AM   #14
The torque converter of bumped distributor are the two things that would effect both issues.
