Old 01-10-2008, 06:16 PM   #1
abadsvt
abadsvt's Avatar
FS: Custom tube frame with a dropmember and air ride
Well i am finally selling my other frame. I need the money to finish my current frame and project. I was building this frame before i went out of town a little less than 1 year ago for work and after i got back i found a c5 drivetrain that i decided to put into my truck so i no longer needed this setup. I wanted to keep it but things have changed a little. Here is a run down on what is installed in the frame. Please email for any questions.
Custom built tube steel frame
Porterbuilt dropmember with power rack and pinion
Brand new cross drilled and sloted rotors with new calipers front and rear
Air ride technologies strong arms
Air ride technologies shockwaves for the front and rear
12 bolt rear end (not posi)
Air ride technologies trianglated four link
Cantilever rear suspension which gives you about 9-10" of lift
Rotors have been redrilled to 5x4.75 bolt pattern for a wider wheels selection
and more....
The frame was designed to have a 7" ride height. The dump height is right about 2-2 1/4" off the ground to the rockers. I designed it so if an airbag ever popped i wont drag the frame or rockers. I am only trying to get the money i have in the frame out so basically you are getting a custom frame for free! Please email me for any quesitons.
PRICE is $7250 for a complete rollin chassis minus the wheels and tires
The wheels and tires in the pics do not come with the frame.
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 01-10-2008, 06:19 PM   #2
abadsvt
abadsvt's Avatar
Re: FS: Custom tube frame with a dropmember and air ride
Here is a few pics showing the dump height and the frame with some sheetmetal
Also one more thing.
The frame has stock spindels. If you put drop spindels it will lay rocker.
(Project truck)
Old 01-10-2008, 06:26 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Wow, heck of a deal. Looks like great craftsmanship. I assume it is a shortbed pu frame? It would almost be a shame to put a body on it and cover it.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 01-10-2008, 07:42 PM   #4
gunkis84
gunkis84's Avatar
wow this post pisses me off... i honestly would have made the 3000 mi + trip to pick this up if you only listed it a month ago.. GREAT DEAL!!!
gunkis84 is offline   Reply With Quote
Old 01-12-2008, 10:44 AM   #5
abadsvt
abadsvt's Avatar
Yes it is for a SWB truck. Thanks for the complements
Josh
(Project truck)
Old 01-12-2008, 10:47 AM   #6
abadsvt
abadsvt's Avatar
I think January is a great month to make that trip. You should still come and buy it. I was debating on selling it since i started my other project a few months ago. Oh' well maybe next time.
Josh
(Project truck)
Old 01-12-2008, 07:55 PM   #7
gunkis84
gunkis84's Avatar
sounds very tempting.. (the trip that is) never been to cal. wife wants to check it out also.. hah i had bought one for 6k and it didn't have all that yours had.. my stomach is STILL turning!! ohh well, your new project is KILLER!! keep the pics comin
Old 01-12-2008, 08:00 PM   #8
gunkis84
gunkis84's Avatar
ohh yea 1 thing josh.. im assuming by watching the frambe build that you ordered your wheels before you had it all together.. how did you know the correct backspacing for the wheels.. (nothing i hate more than nice rims tucked into the fender 2" too far on each side) and also, when you get a chance what is the width of your rear axle.. i think mine is narrowed.. but not 100%
Old 01-13-2008, 01:52 PM   #9
abadsvt
abadsvt's Avatar
I actually when a different route. I decided what wheels i wanted then ordered them with as much backspacing they offered. I was planning on shortening the rear end but it just fit. I am not sure what the width of my rear axle is but in a few days i should be putting my rims and tires on the new frame so i can get a measurment for you.
Josh
(Project truck)
Old 01-16-2008, 10:40 AM   #10
abadsvt
abadsvt's Avatar
ttt
(Project truck)
Old 02-08-2008, 12:58 AM   #11
1LoC10
Insert Title Here
1LoC10's Avatar
cant believe nobodys jumped on this... maybe you should try $7000 with the wheels...lol
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 02-10-2008, 11:43 AM   #12
abadsvt
abadsvt's Avatar
Not a bad idea
(Project truck)
Old 02-10-2008, 11:58 AM   #13
abadsvt
abadsvt's Avatar
New price is $6850. I am also willing to build a new frame using all of the components from my frame like shockwaves, dropmember, strong arms and so on. The reason i am willing to do that. There were a few areas that i could have done different. For example. The rear rails sit about 1-1.5" above the rear end so if I lowered it by an 1" or so that is that much more bed space you get. That kind of things. Plus you get a frame a little more personalized to you specs. That way you get a perfect setup for your needs.
Josh
(Project truck)
Old 03-19-2008, 10:16 PM   #14
71'tahoe
71'tahoe's Avatar
Is the drop memeber the bolt in version of the c-10 that you welded in place or does porter have them in weld in versions?
71'tahoe is offline   Reply With Quote
Old 03-20-2008, 08:01 PM   #15
abadsvt
abadsvt's Avatar
Nathan custom made this dropmember for my specific for my frame. I think it was his first weld in one that he made. I could be wrong though. It came out SWEET!
Josh
(Project truck)
Old 03-20-2008, 08:09 PM   #16
71'tahoe
71'tahoe's Avatar
Thanks for the info..
